Question about Edu-Science (10166) Telescope
It doesn't seem possible to tighten the telescope to the telescope mount. The tightening knob seems too loose. Also, there is no way for us to get our fingers into the narrow space to tighten it.
  • 3,186 Answers
Sure wish you would have NOT bought that telescope. It is a 50mm refractor which is exactly the same size as a pair of 10x50mm binoculars.
The binoculars will have better optics than that telescope.
If it is already broken? Can you return it? You cannot buy a usable good telescope for less than about $200. Here is a good beginner telescope.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=08942 6 inch mirror
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=09804 4 inch mirror
Posted on Dec 12, 2009
I have just assembled the Tasco 70x 800 refractor, but there does not seem to be any way of adjusting the altitude. There is no knob to loosen the mount, only a nut which is hidden inside the mount which...
There appears to be a KNOB underneath that you loosen or tighten -- and also one on the altitude. Adjust these knobs so that you can move the scope but with some friction---here is the manual
http://www.tasco.com/products/manuals/SpaceStation6LIM_49060700_49070800_49114500.pdf
Apr 23, 2011 | Tasco 49070800 Spacestation(r) 70az...
The dovetail mounted scope (optical tube assembly) is smaller than the mounting block - with the mounting block surface top section flat while the scope peice is angled (?). I can tighten both the knob...
There are only two types of dovetail bars and saddles. A "Vixen style" and a "Losmandy style". One can be mistaken for the other. You probably have a Vixen style. tighten both knobs and you should be OK. Many dovetail bars have a screw hole in the end to place a bolt as a safety device if the bar should slip on the saddle -- the bolt would catch it and prevent the scope from falling off.
Dec 27, 2010 | Vixen VMC110L with SKYPOD Mount and...
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
Jeep Rubicon Outlook telescope 360X. While I was
Doubtful if you can get parts. Is this a new telescope? If it is return it.
Another possible solution may be to go to a well stocked hardware store and see if they have a bolt or pin that will work.
Read our telescope guide on our Astronomy club web site: The scope is very very small and will never acheive 360 power. I know it is only $69 but the rules for optics say a maximum of 50 times aperture. You front lens cannot be over 1.5 inches so if the optics were perfect and the sky was perfect about 75 power is the maximum possible magnification.
Read our beginner telescope article on our Astronomy club web site here:
http://www.texasastro.org/telescope.php
Nov 15, 2009 | Jeep Desktop Telescope
The alt/az adjustment knobs don't work
Are you sure the set screw is tightened? Some scopes have limited adjustment ande the screw need to be "centered" so you can adjust in both directions.
If all else fails Orion has a good customer service department:
http://www.telescope.com/control/view/page?p=custservice
Oct 29, 2009 | Orion Optics
I have a Meade ETX-90EC. I cannot tighten the vertical lock to engage the motor. Motor works fine (I think, I can hear it turning) but the knobbed dial just keeps turning (clockwise) and never seems to...
It's a simple solution!
Take the knob off, and use a simple washer, will will hold up in between the plastic and metal surfaces.
This should be your solution!
Aug 07, 2009 | Optics
Balancing a 70mm refractor tube
Looking at pictures I found on the web, I see a knob on the bottom that tightens the scope to the dovetail bracket on the bottom of the scope. First attach all of your eyepiece then loosen that knob and slide the scope back or forth until it will balance without tightening the knob. Or if you do not have the manual you can download it for free here.
http://safemanuals.com/user-guide-instructions-owner-manual/MEADE/70%20AZ-T-_E
Jan 16, 2009 | Meade Telescope
Right ascesion slow motion control knob loose, does not work
The RA knob has a setscrew that fixes it to the shaft. Just need to find the correct size and tighten.
Jul 06, 2008 | Meade LX200GPS Telescope
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Focusing problem
it could be the grub screw on the knob needs tightening. If it is loose, the knob will just turn but the shaft wont.
Dec 22, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Edu-Science (10166) Telescope Logo
126 people viewed this question
Top Edu-Science Optics Experts
Craig Butler
Craig Butler
john cordey
john cordey
Geoff White
Geoff White
Are you an Edu-Science Optic Expert? Answer questions, earn points and help others
