Question about HP DeskJet 932c InkJet Printer
The ink light on my printern is flashing. I
The ink light on my printern is flashing. I changed out the catridge but I can't get the light to stop flashing and the printer to work.
  • 73 Answers
Open your cartridge door pour some hot water and then close it and then take an egg put chilly powder and salt on top of it and then garnish it with some onions. heat your printer. it will be alrite.
Posted on Dec 23, 2009
My canon mp280 pixma is flashing an error code p 22 and the color ink light is flashing also
Your color catridge is not install well, remove the catridge and replace again.... if it is not possible than change your color catridge..... thanks
Aug 14, 2011 | Canon PIXMA MP180 All-In-One InkJet...
Red Flashing lights
Hey,
Remove the cart ridges, restart printer, does the lights still flash? restart printer, place cartridges back in, make sure the tape is removed from the cartridge. also you can try cleaning the contacts.
So after you have connected the carts again, restart printer. how is it?
Thanks,
Ekse
Sep 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Red light Flashes all the time when ON and screen says; "replace catridge" even though the ink tank is changed.
Hello, maybe it is not placed well. you have to check on the catridge that is bought, to know if the catridge is well doing on the printer.
Apr 02, 2011 | Canon MultiPASS MP390 All-In-One InkJet...
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
I replaced the blue catridge and now both red
If the red lights are flashing simultaneously, it means that there is something blocking the printhead from moving. check if all inks are installed properly and the ink carriage cover is closed tight. If both red lights are flashing alternately,it means that the waste ink pad is full and needs to be replaced. This part is not user replaceable so you need to take in the printer for service.
Apr 11, 2010 | Epson Stylus C88 InkJet Photo Printer
Replace ink cartridge before it is empty using Windows Vista
Get the new ink, when the ink light begins to flash, that will be the time to change it. Press the ink/cleaning button, the printhead will advance to the left, open the cartridge door, replace ink, close the catridge door, and hit the button again.
thanks adi
Dec 29, 2009 | Epson Stylus 880 InkJet Color Printer
Red light flashing above ink symbol but plenty of ink
hello! the ink indicator is showing because the catrigde sensors could be coated by some dirt or ink . try cleaning the catridges slot with soft material .then put it on
Jul 10, 2009 | HP DeskJet 940c InkJet Printer
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
HP DeskJet 932c InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
