Question about Refrigerators
Ge side by side is getting a pile of ice on freezer floor
My ge profile side by side is getting a pile of ice on the floor of the freezer that every few weeks i have to break out. The water looks like it is running down the back wall from the top? The ice maker seems to be working properly.Any ideas?
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Dec 12, 2009
Makes too much ice and it overflows
You cannot - this is a design issue that really cannot be fixed since the arm that senses the ice level cannot get caught up in the bucket or it would break every time you opened the freezer. Any fridge brand of this type has the same issue.
May 28, 2010 | GE Profile PSW26P Stainless Steel Side by...
Our new GE Profile refrigerator makes too much ice and when you pull out the freezer ice drawer the ice tumbles out into the freezer and onto the floor. How do I make it stop over making the ice?
there is a kit you can git to put on the arm that tells how much ice it has ..or you can carefully bend the arm down too tell it it is full hope this helped
Mar 11, 2010 | GE Profile PSW26P Stainless Steel Side by...
Where is drip pan on profile side-by-side
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water from GE Profile Refrig/freezer drips down back inside freezer wall and fills up, bypasses drain and fills up and leaks into floor.
Hi, Is it bypassing the drain or is the drain plugged? The most common is that the drain hole gets iced up and them overflows onto the floor.
Just wanting clarifcation.
Jul 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Mar 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
