Question about Whirlpool Duet GHW9150P Front Load Washer
Clean pump - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 1,891 Answers
Remove lower panel 3 screws / just to left of center ( the clean out twist to remove and clean out screen/tray / clean the threaded area and seal before reinstall . and yr done . mm
Posted on Dec 12, 2009
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Tip
Braun cleaning stand - pump will not run during cleaning cycle
My Braun shaver cleaning stand ran perfectly for several years until recently. The system would perform a cleaning cycle but I could tell something was awry because the shaver head didn't have the usual pleasant after-smell of the cleaning fluid. The blower motor inside the cleaning stand would run but the pump motor to spray the fluid into the cutter/foil assembly could not have been running.
WARNING - If your Braun Cleaning System and Shaver are under warranty, you will probably violate the warranty by pulling it apart for repairs.
I opened the cleaning stand (make sure you pop the upper section to allow removal of the cleaning fluid cartridge and let the system drain first! ) by prying the dome section from the bottom section at the circular gap around the body of the cleaning stand.
Once inside I inspected all the connections and located the pump motor. Using an external power supply (+12VDC) I confirmed the motor was either bad or locked down. (Remove the wires so that you do not subject the control pcb to the external supply voltage) While inspecting the bottom side of the pump section (this is where the fluid is drawn in) I noticed a white toothed gear inset into the white bottom section of the pump well.
I used a small screwdriver to rotate the gear to make sure the mechanics of the pump were not bound up. They were free and I tested the pump motor again. SUCCESS! The pump motor ran normally!
I then reassembled the cleaning stand and tested it with the shaver and Braun supply.
If I have more trouble, it is likely that the brush contacts of the pump motor are worn and when I rotated the pump gear, it placed the commutator in position to allow the motor to operate.
on Jan 18, 2009 | Braun Syncro 7526 Electric Shaver
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Dec 03, 2014 | Haier HLP21E Top Load Washer
I've a whirlpool sixth sense washer and the clean pump light comes on mid cycle. I've cleaned the pump filter, cleaned the pump, checked the pipes for blockages, and today replaced the pump, only to fine...
You might have a loose connection to the pump or from the pump to the CCU Remove the top of the washer and make sure that the wire coming from the pump to the CCU is fully in and it's not loose
Apr 30, 2014 | Washing Machines
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
If you need further help, I’m available over the phone at https://www.6ya.com/expert/justin_3ae27a9d61d6acd4
Apr 15, 2013 | Washing Machines
WL80T65C - error 245, can you please advise on this error?
The error 245 is a drain pump stall. Take the pump out from the bottom of the machine (2 screws) and clean it out. The resistance between the red and blue, blue and white, and red and white wires should be 16 ohms, if not, replace the pump.If the resistance is ok then clean the drain pump and drain hose to which the pump is connected.Clean it with normal tap water.Then refit it and check.In most of the cases cleaning the pump and hose helps.In some cases the pump has to be replaced/.----------- This will help.Thanks.Helpmech.
Jan 20, 2011 | Fisher and Paykel Washing Machines
F2 message appearing on washer, what does that mean
Something clogging the pump or drain line. Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
This is how to clean the drain pump catchment: Remove the bottom front panel to see a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean out.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
New cartridge-wont pump cleaner
The cleaning fluid "pump" is actually a small Mabuchi 6V DC motor that uses two small plastic spur gears in mesh to "pump" the fluid up a tube into the cleaning reservoir. Mine has died also and I cannot find a replacement motor. The cheapest I have found the base is here: http://www.electricshaverstore.com/get_item_scc1_braun-syncro-clean-charge.htm Good luck, Lynn Livingston
Jul 01, 2007 | Braun Syncro 7526 Electric Shaver
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
