Question about Samsung SyncMaster 730MW 17" Flat Panel LCD Monitor
All touch Keys locked?
I have this monitor and somehow the touch keys, Power, source etc...
were locked and finding nothing in the user manual to unlock any help would be appreciated!!
Thanks
Kurt
I had the same problem. Hold the menu button in for 5-10 seconds and it will unlock.
Posted on Jun 02, 2008
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6
http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
Oct 28, 2015 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have an LG Optimus TMOBILE phone, and the talkback is on, I can't get to the Assisablity screen in the settings. How can I disable this?
get your manual here,
LG Support USA Customer Service and Technical Support LG USA
1.From the Home screen, touch the Menu Key .
2.Touch Settings > Privacy > Factory data reset.
Read the warning and touch Reset phone
If your phone does not restore to the original condition, use a Hard Reset (Factory Reset) to initialize it.
When the phone is turned off, press and hold the
power/lock key and down volume,after 5 seconds, keep pressing the previous keys and touch and hold the Menu Key + Back Key (must be done before the touch key LED lights turn on). When the LG logo appears, release the Power/ Lock Key but keep pressing the rest of the keys. The phone will perform a factory reset immediately. WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset
May 14, 2015 | LG Cell Phones
How do I hard reset my virison lg vs920 modle phone
Follow the following steps:
  1. Turn the Power Off.
  2. Touch and hold the following keys at the same time for 8-12 seconds: Power/Lock Key + The Volume Down Key.
  3. Press the Power/Lock Key when you see the pop-up "Permanently Erase User Data & Reset Settings?". Press the Power/Lock key to confirm, or touch any Up and Down key to cancel.
  4. When you press the Power/Lock key to confirm, another pop-up stating "Are you sure you want to continue with erase?" will show up. Press the Power/Lock key to confirm or touch any up or down key to cancel.
  5. After pressing the Power/Lock key, your phone will be restored to factory settings.
Please remember that when you perform factory reset, then all your user applications and user data will be deleted.
Please make sure you back up any important data before a factory reset. I recommend Titanium Backup (https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackup&hl=en). However, your phone should be rooted.
The picture attached should show you the buttons highlighted in green.
However, if your phone is still in working condition, then you can follow the following steps:
  1. From the Home screen, touch the Menu Key.
  2. Touch Settings > Privacy > Factory Data Reset.
  3. Note: Touch the check box to erase all contents from your microSD card when the phone is reset.
  4. Read warning and touch "Reset Phone".
Hope that helped.
Cheers,
Sami Memon
Aug 17, 2012 | Cell Phones
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
Laptop locked
puddy cat has stood on whats called a sticky key if you have a user book it will tell you how to release it.i cant quite remember the exact key to use but you have to press and hold down the fn key then hit one of the F keys.F2 for example, i just cannot remember which F key it is.
hope this helps
Jun 04, 2010 | Dell XPS M1530 Laptop
My remote in my keys no longer work to unlock my doors or trunk. I have changed the batteries in the keys, the light blinks when I push it. What could be wrong? I have a 2001 GS300
Most likely: You have to now "reprogram"your key fob and car to recognize each other. Look in your User's Manual for the car or, if it's an aftermarket fob/lock system, look in the user's manual for that. If there's nothing about battery replacement/reprogramming procedures, and it's a factory system, head into a dealer to reprogram it. It could run you up to $120, but that's cheaper than buying a new fob or system. If it's and aftermarket system and the manual says nothing, go to the place you had it installed (repair facility, Future Shop, etc) and have them reprogram it. If they installed it, they should know how to reprogram it.
Keep in mind, that's only the most likely option. Another possibility is that the receiver in the car, transmitter in the remote, or lock actuators/relays, etc in the car are the issue. It may not have been batteries in the first place at all. That said, it was most likely the batteries, and your best bet is trying to figure out how to reprogram the fob and car to recognize each other.
Jul 10, 2009 | 2001 Lexus Gs 300
Keys locked.
The user's manual is available from RCA's website - it will show you the location of the lock switch.
Jul 03, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4002 locked keys
Do u have the hold button switched up? If so just switch it down to unlock the keys.
Apr 01, 2008 | Audio Players & Recorders
Samsung LCD "keys locked"
Hey it taken me a few years to find a solution to this problem.
I also own a Samsung syncmaster 2032mw.
BTW you must hold / use the "Menu key on the side of the TV", as holding the remote key dosen't work!!
Many thanks dopeNL
Dec 28, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung SyncMaster 730MW 17" Flat Panel LCD Monitor Logo
247 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
