Question about Dishwashers
Maytag electric range buzzes and resets clock when key is pressed
Maytag MES5552BAB electric range - sometimes when I push the Bake key (also happens with other keys), there is a momentary electrical buzzing sound or hum in the controls unit, the clock resets randomly, and the display shows the number 30. Pressing Bake again gets me going (except the clock is off). It only happens on the first key press when I go to use the stove. If the first key press works OK, then additional key presses are fine also.
What needs to be replaced to fix this?
    President:
  • 1,891 Answers
The membrain has a almost stuck key / if the clock has w warped face . then some of the buttons are almost closed. asn causing some problems . it won't get better in time if will fail . and the clock will have to be replaced . .. mm hope this helped .
Posted on Dec 12, 2009
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Nov 09, 2009 | Maytag MER5775Q Electric Kitchen Range
When i hit bake the clock resets
I've seen this happen on some models due to a bad temperature sensor probe or bad oven door switch. This can also be caused by a problem with the electronic control. If you are able to eliminate the probe and door switch as culprits, we can help you with the control board. We repair oven controllers at www.fixyourboard.com.
Sep 22, 2009 | Maytag MER5775Q Electric Kitchen Range
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Maytag slide in range - MES5752BAW - when you press BAKE or BROIL the power cycles off and the number 30 flashes on the display then the power cycles back on and the clock is reset to 12:01.
I had similar issue with my Maytag slide in range MES5552BAB. Pressing Bake or Broil would sporatically cause clock display to go blank, show "30" then reset clock to 12:00. Under warranty, the service technicians replaced the clock unit twice. On last visit the range performed the error while technician present.
The suspected problem is that the clock unit is experiencing high frequency interference.
The proposed solution is to place noise suppressors on L1, L2 and Ground wires at the clock. (Noise suppressor: Ferrite beads, Sears Part #12001500.) Reverse L1 and L2 at the pigtail terminal block.
May 06, 2008 | Kitchen Ranges
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
