Question about KWorld DVD MAKER USB 2.0 (660448660114)
Black and white and no sound!
I have connected the DVD maker to my vcr and started up powerproducer, but when I try to capture the video, the picture shows in black and white and in poor quality. There is also no sound. I can still record it, and when I play it back there is sound, but the picture is awful. Do you have any suggestions?
  • silver_grey_ Dec 12, 2009
    The video I am trying to copy to my laptop is a home video that was recorded from the TV a long time ago. It shouldn't be copy protected. Also, when I plugged the DVD maker into the TV and recorded onto my laptop from there, the result was the same; black and white with no sound until after I'd recorded.
  • 488 Answers
You are trying to copy or record a copy protected video or your VCR has internal copy prevention turned on. If you wish to copy tapes or dvd's, use a PC based system. You can also pull the raw video information off the VCR if you know where to connect to on the video board of the VCR. I cannot tell you how to to this as I have no idea which VCR you are using however, google the brand and model of your VCR, find a schematic and you should be able to pick the raw video feed into the video decoder chip and use that. Use shielded cables and NEVER undertake any work inside anything when it is plugged into the power outlet, disconnect it first by removing the plug from the outlet (never rely on the switch either).
Posted on Dec 12, 2009
  • Dave Sargent
    Dave Sargent Dec 12, 2009
    In that case, I would suspect a faulty capture card or USB issue.
    Home video's should normally not be protected ( but can be if you wish) and most TV programmes are not protected so it sounds like your problem is elsewhere. Have you tried copying direct from a video camera with the A/V output. If that is also below standard, suspect the Kworld DVD maker..
How do I hook up my dvd/vcr to the tv
On the back of the cinavision you have two groups of sockets. The yellow socket under Video out is picture. Red and white is sound. Connect them to the TV's yellow red white sockets marked Video In 1. This connection will give you picture and sound from either the VCR or the DVD deck.
There's a better picture quality available for DVDs only from the Component video out sockets (green red blue). Next to them is another set of audio sockets (red white). Connect all five sockets to the TV's input number 2. The colours match up. The picture from Component will be clearer and sharper.
On your Sharp TV remote, select Video 1 to watch VCR, and Video 2 to watch DVDs.
Nov 07, 2014 | Sanyo DP39842B 39" 1080p LCD TV...
How do you transfer video VHS to DVD?
I'm glad to provide the instructions to transfer video from VHS Tape to DVD. You may purchase a DVD Recorder and connect the VCR to its A/V input to record the videos directly to a DVD. There are VCR/DVD Combo Recorders available where you can dub from VHS to DVD without using another VCR.
Alternately, if you have an A/V interface in your Computer, you can connect a VCR to the Computer and capture videos using Windows Movie Maker or any other video capture software. Once you transfer the video to the computer, you can burn the videos to a DVD using the DVD burner in the Computer.
Thanks for understanding. Please let me know if you require further assistance or any clarifications.
Thanks for using Fixya
Aug 08, 2011 | Televison & Video
I'm trying to import footage from my vhs onto my laptop (i'm using vista). I can get the videos, and the quality is okay, but there isn't any sound. I tried with both PowerProducer and PowerDirector but...
your codec is not compatible with your system. please download from this link http://www.codecpackguide.com/klmcodec.htm to have codecs that your need. hope this helps!
Feb 20, 2011 | KWorld DVD MAKER USB 2.0 (660448660114)
I cannot receive sound from VHS video tape during capture with my Tevion High Speed DVD Maker. What VCR to PC connections do I need?
The audio cables - normally colored red and white (RCA) cables to the computer with a sound card.
Nov 29, 2010 | Computers & Internet
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
I am capturing video from a VCR to a PC using Windows XP (SP3), and using DVD Maker hardware. I am doing this using Windows Movie Maker, but have also tried Nero 7 and the result is the same.Both sound and...
I talked to someone who is a professional video editor, and he suggested the first thing to try was to change the USB port to which the DVD Maker was connected. This wasn't something which would ever have occurred to me, but hey presto it worked! Aparently USB ports are sufficiently delicate in terms of video transfer that they will work with normal devices, but some may not work well for video. I hope this helps someone else.
Aug 01, 2008 | Televison & Video
What do I do to get videos out of my everio JVC 3.o camera and into the Cyberlink Powerproducer program?
just usb and connect it to your computer if the camera has a usb interface and make them to what program or software that you like. but i prefer ulead movie maker. hope that helps
CHARCOIS
Apr 06, 2008 | JVC Everio GZ-MG27 Camcorder
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
KWorld DVD MAKER USB 2.0 (660448660114) Logo
721 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Alun Cox
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
