Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
I have never installed a flash drive want to now how step by step
    Problem Solver:
  • 14 Answers
And u don`t have to - just pop it into free USB port and of u go - let do MS do the rest. In case of Apple don`t forgot to "eject" first
Posted on Dec 12, 2009
Reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
I am a student in school, and I am not to computer savvy on Flash drive.. It did not come with any instructions on how to use it. It is a Cruzer USB 2.0 Flash Drive (4GB) Can you help me with step-by-step...
  • Boot up your computer and find an open USB port. These are small, rectangular ports typically on the sides or backs of laptop computers, or on the fronts or backs of desktop towers.
  • Plug your flash drive into the USB port. The drive will slide in only if it is turned in the right direction, so if you have trouble inserting it, turn it over.
  • Make sure your computer sees the flash drive. It should launch a menu, letting you know that it has found a new storage device. You can choose an option from the menu or close the menu if you don't need to immediately access the flash drive.
  • Install the flash drive's driver if your computer doesn't recognize the flash drive. The flash drive's packaging should include the manufacturer's website address. Open your Internet browser, go to that address, and download the flash drive's driver from the site. Install the driver on your computer. After that, your computer should be able to recognize your drive.
  • Jan 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    I can't format my PNY flash memory, and when it be connected to USB port the computer speed decreased. Heip me please.
    Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
    1) cd\ press enter
    2) c:/>format drive letter (eg d: f: e: etc) press enter
    3) read message carefully and then press y
    now yours flash drive formatted
    Aug 03, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
    Flash drive can't format and once data is saved,
    1) cd\ press enter
    Jul 27, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    How to install driver for tdk 4gb flash drive
    hi...
    please connect your flash drive to your computer and it wil automatically installs the driver for that flash drive,it shows 'installing driver' and finally it wil come as 'device installed and ready to use'. You can start using the flash drive.
    if this doesnt happens follow the below steps,
    1.Insert the CD and it automatically starts to install the software.
    2. please click on NEXT to install the driver software and click on FINISH to complete the installation.
    when you complete the installation you can start using your flash drive.
    thanx
    Jul 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    I want to "lock" the flash drive with a password.
      Encrypt Individual Files and Folders on a Flash Drive
    1. Step 1 Choose "Tools" from the menu bar at the top of the program, such as Microsoft Wordmag-glass_10x10.gif, and pick "Options."
    2. Step 2 Select "Security" from the many tabs displayed in the new popup window. Create a password in the "Password to Open" or "Password to Modify" section and click "OK" at the bottom of the box.
    3. Step 3 Confirm your password when prompted. Drag the password protected files to your flash drive. To open a protected file, enter password when prompted. Remember, passwords are case sensitive.
    4. Encrypt Entire Flash Drive
    5. Step 1 Download and install the freeware program "Cryptainer LE" onto your PC or laptop. Enter a meaningful password from 8 to 100 characters and define the file location and size, which you can change at a later time. Enter your password when prompted.
    6. Step 2 Install Cryptainer Mobile when the Cryptainer LE installation is complete. Select "Tools" on the menu bar at the top of your screen. Select "Install Cryptainer Mobile" and follow the prompts. The Mobile version comes with the LE download.
    7. Step 3 Close the LE version on your desktop. Select a location and meaningful password for the Mobile version. To protect important files and folders, drag and drop them into the vault, the location of the encrypted files.
    Jun 24, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
    When I am going to install windows xp give message, can not find storage media to install xp.(hard drive show in BIOS) what is the reson for this message
    Try Step 1 & Step 2. If you are not able to perform recovery console, then follow Step 3 & Step 4.
    Step 1. http://www.articlesbase.com/data-recovery-articles/could-not-install-windows-xp-due-to-hard-drive-damage-1244273.html
    Step 2. http://ezinearticles.com/?Could-Not-Install-Windows-XP-Due-to-Hard-Drive-Damage&id=2944653
    Step 3. http://support.microsoft.com/kb/314058
    Step 4. http://support.microsoft.com/kb/307654
    Hope it works for you.
    Warm regards,
    Anirban Mazumdar
    Oct 16, 2009 | Memorex (32025535) DVD-R Storage Media
    Massstorage
    This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
    Required:
    · USB Flash Drive (4GB+)
    · Microsoft OS Disk (Vista / Windows 7)
    · A computer running Vista / Windows 7
    The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
    Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
    diskpart
    list disk
    The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
    Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
    select disk 1
    clean
    select partition 1
    active
    format fs=NTFS
    assign
    exit
    When that is done you’ll have a formatted USB flash drive ready to be made bootable.
    Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
    Change directory to the DVD’s boot directory where bootsect lives:
    d:
    cd d:\boot
    Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
    bootsect /nt60 g:
    You can now close the command prompt window, we’re done here.
    The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
    This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
    I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
    Jan 23, 2009 | Computers & Internet
    SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
    286 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
