Question about iLO DVDR04
Tray will not open..about 2 yrs old...and just started
  • 1 more comment
  • Anonymous Apr 07, 2008
    ilo dvdro4 tray will not open
  • steveh77 Sep 23, 2008
    I have same problem. Don't remember if disk in or out. Has been plugged in for a long time without use. Worked great until this. Don't know the solution. I'll try to take the unit apart and open up the tray.
  • upset4now May 03, 2009
    Disc has been in the tray for a while. Tray would not open; however, it reads the disc if I push play!! Don't know what to do. Anyone knows? (other than taking the whole thing apart...)
I have this problem with my ILO quite often when leaving a disk in for a while. The only way to fix it is to take apart the recorder and manually remove the disk. The last time that I did this I dabbed the sticky part of the ILO with a Kleenex (to tone down the "stickiness"). Time will tell if this worked, but so far so good...
Posted on Apr 29, 2008
Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer may be partially frozen or torn..RDS
Apr 23, 2010 | Refrigerators
My DVD tray will not open, and with no disc inside the display says 'reading' constantly. Any thoughts?
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. I had to do this on my unit and therefore I recommed leaving a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Oct 11, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Disk tray for xbox 360 problem
try blowing in the xbox 360's tray in side where the laser or let it sit open tray for a little bit do things on it and then close tray it might work it does for my xbox most of the time im 12 yrs old
Jun 28, 2009 | Microsoft Xbox 360 Console
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
2 yrs old, getting a 4 flash alarm , "Open High Circuit" any help?
check for a reset able round limit switch in the burner area if fires up make sure filters are clean and no signs of flame roll-out in the burner area when fan comes on this furnace should still have mfg parts warranty left
May 16, 2009 | Goodman GDS80904BNA Open Flame Heater
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
CD drine issue
To manually open the CD Drive, straighten a paper clip and insert it into a tiny hole in the front of your CD drive and push the paper clip gently into the drive and the tray should then pop open.
Open and close this several times, then insert a disc into the drive and see if it will read the disc.
If not the drive is dead and needs to be replaced.
Nov 18, 2008 | Acer (KV.16X04.007) DVD Drive
iLO DVDR04 Logo
123 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
