I have a maytag performa top washing machine it is squeeling.
I have a maytag performa top washing machine and it is squeeling. I think it is a belt or something that has jamed betwen the ajatater and drum. How do you get it apart, I do not have the manual.
Thanks, Bob
    President:
  • 1,891 Answers
Squeeling may be the belt caused by the pump failing . roll the belt off and see if pump turns freely . and forget about what i told you albot the removal of agit . i don't think anything is under it . mm
Posted on Dec 12, 2009
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Agitator is slipping on wash cycle every thing else is working fine where should I look for the problem. Machine is Maytag Performa PAV3200AAW Rev 12
If the drive belt is worn or loose, that could cause your problem.
drive belt is on the bottom of top loader
and behind front loader.
Nov 14, 2012 | Maytag Washing Machines
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Maytag performa making LOUD squeeling noise when agitating and spinning
Most likely the tub bearing has gone bad on your washer.
Apr 07, 2011 | Maytag Performa PAV2200
I have a top loading Maytag Performa washing machine and the tub doesn't spin
You will need to replace the belt on the machine. This is a fairly easy job, just go to an appliance repair shop, tell them the model number and they will get you a new belt. Then lay teh macine on its side and replace the belt. There should be a routing diagram on the washer, and if not you can get on online.
Mar 19, 2011 | Maytag Washing Machines
Replace belt on pye4500ayw
i lifted up the top and unscrewed the front of my maytag dyer pye4500ayw a very thin belt was at the bottom. who do i replace this belt and where does it go?
Feb 07, 2009 | Maytag Performa PAV2200
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
you need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Dec 20, 2008 | Maytag MAV8600 Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Washing Machines Logo
163 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
