Question about Logitech Z-5500 Computer Speakers
Logitch Z-5500 Hi there can any one help me my subwoofer on my z-5500 speaker system is not working properly , been experiencing this problem after switching the on/off switch behind the sub-woofer , the control unit wrks fine - even replaced the Fuse , still no luck with the problem Many Thanxs Asab Ali West Bromwich ( uk ) E-mail: [email protected]
  • asab
    asab Jan 21, 2008
    Thanxs ! for the solutions bladeexp and open sky i have contacted logitech this afternoon the product is still under warranty , asked them for an replacement product to be shipped out to me , awaiting approval by logitech on receipt of proof of purchase
    Kindest Regards as always
    Asab
This been solved yet?Well if not, I'd suppose it's a loose connection
within the sub woofer enclosure.About the only thing you could do is try to get it fixed like Open SKy mentioned, or if you're a do-it
yourselfer disassemble the sub and try to locate the problem.
If it isn't a loose wire I'd say it might be beyond repair, I've
taken a look within mine, but I'm guessing it's really complicated.
Hope this helps!
Posted on Jan 26, 2008
Hello Asab
For more solutions, I will suggest that (1) You remove the connection cable between the speaker and the control unit and cheack the contacts on the control unit and speaker then reconnet it. (2) Make sure the control unit is on and there is a link to the soket which the speaker is connected to. (3) If the problem remains, change the cable that connects the control unit and the speaker.
Thanks
Airen Kenneth
Posted on Jan 22, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Asab
First things first
1) Check the on /off SW. for any dust, or broken line inside. if you can. If not get it repaired from near computer shop.
2) RMS the subwoofer, if you got warranty.
3) other than that, if you can buy a new sub, you can go and buy it, of cost effective is better.
good Luck
Posted on Jan 21, 2008
  • Carlos L. Burgos
    Carlos L. Burgos Jan 21, 2008
    Thanks to you!
    always
    Open Sky
    Problem Solver:
  • 8 Answers
Ok what sound card do you have on your system maybe your sound card is not working grate
6ya staff
SOURCE:
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
99 A6 Subwoofer and Amplifier
I have a similar problem on Audi A6 2.5 tdi year 2000, is just that my subwoofer is working fine, but the rear speakers have no sound and the rear satellites on the same ciruits are working just fine, I cannot explain this! I have taken apart the rear speaker and teasted with an ipod and one is working fine but the other is dead! I don t know if there is any connection, or there is a filter for the rear speakers and if one speaker is dead there will be no sound on the other speaker! but as i said on the same cables satelites are working well!
Mar 16, 2010 | 1999 Audi A6
Looking for a subwoofer for logitechZ-5500
Hi, As Logitech does not sell this spare part, I suggest you to check on website such as ebay. Thanks and have a nice day !
J -
Mar 04, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
When I change the fuse in the z-5500 it
at this point your hands are tied to fix these due to a capacitor failure or whatever. you can try wrapping the fuse in aluminum foil but this may cause even further problems but i have seen it work before. be sure to keep a close eye on these if this works because the fuse is ultimately a safety device.
Jul 11, 2009 | Logitech Z-5500 Computer Speakers
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
Remote control for Z-680
I have 2 sets of speakers systems for the Logitech Z-680
Both sets included Subwoofer and 5 speakers.
Note: there is no controller on both just the speakers
I bought one set and the Controller went out.
Logitch sent me a new Z-680 system then the second controller went out but speakers work great.
1 system speakers were never used
2 system speakers used for about 4 yrs (speakers work great)
Also have 2 remotes (never used)
Both speaker systems are for sale
Remotes will sell seperatly or with systems
If in need of the subwoofer speakers must go along
Email me if interested
[email protected]
Jun 05, 2008 | Logitech Z-680 Speakers and DVD218 System
Control and amplification circuit boards are not recieving power
If there are no visable ways to get into the box from the back then you must remove the speaker from the from and gain access through the hole the speaker came out of. It is not too uncommon for speaker units to built this way. Good luck.
Feb 06, 2007 | Logitech Z-680 Speakers and DVD218 System
Logitech Z-5500 Computer Speakers Logo
498 people viewed this question
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
