Speaker connection for LG W2053TX monitor
Hi, just got an LG W2053TX monitor and cannot for the life of me figure out how to connect speakers...can anyone help, please!?
  • 488 Answers
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Posted on Dec 12, 2009
How to connect internal speakers on an acer xw233db lcd monitor
Hi Mirta,
If your LCD Monitor didn't come with internal speakers, you will not be able to add anything internally.
10base2
Apr 01, 2012 | Computers & Internet
My LG Flatron W2053TX screen is stuck on "analog
The monitor will go off if there is no detected signal from the computer. Check your cable or try a different cable.
Check to see if there was an installation disc with it that must be installed.
Some monitors have a built in anti theft feature which disables the screen if it does not see the correct computer hooked up to it. These can be a real pain even with the right computer...
Apr 14, 2011 | LG Flatron L1919S LCD Monitor
Sound not playing correctly via the speakers on the monitor Back ground music but no voice
sounds to me like you may have the monitor speakers connected to the wrong port. It typically connects to the computers Green speaker jack. If it is connected properly, look in the control panel for audio/ speaker properties, change the speaker configuration to stereo speakers, instead of 5.1 speakers. you are likely hearing the rear channel of 5 speaker setup at the moment.
Aug 29, 2010 | NEC MultiSync LCD1735NXM (Silver, Grey)...
No sound, other monitors have a input jack for sound but not this one.
Some monitors have built-in speakers and others do not have them.
In this case you need to purchase separate external speakers to connect into your computer. If your computer has audio output for surround sound, then you can buy 5.1 surround sound speakers. These will have 2 front speakers, 2 back speakers, a center speaker and a sub-woofer speaker..
Jun 04, 2010 | LG Flatron L2320A 23" LCD Monitor
Dimension 8400 PC Desktop: Where do I connect the monitor mounted speakers to...
you connect the monitor's speaker lead to the speaker jack or line out jack on the sound card.
May 03, 2010 | Computers & Internet
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
Feb 14, 2010 | Paradigm Monitor 9 Speaker
Cannot connect speakers to new monitor
if these external expeakers look something like these.. http://www.kelley.iu.edu/TS/z_images/AS501ultra.jpg
those are made specifically for Dell monitors on very exclusive models and they will not fit any other, as the monitor itself provides the power and has the audio output for them.
Dec 12, 2009 | Computers & Internet
New moniter old computer
does monitor have speakers if yes it will have a speaker connection with the video lead connect it to speaker output on computer.
If monitor does not have speakers you will need to buy or use external ones
Jul 15, 2008 | Computers & Internet
Speakers in monitor wont work
hi there, 1st check the connection of cable speakers. then check the volume control, switch it mid range setting. then check the hardware device if there is no conflict with any device. try to reset your system once again and if still same problem, you may have a Speaker problem, maybe the connection inside your monitor with the speaker has a loose connection or some electronics part failure. TY
Dec 23, 2007 | HP vs15 15"LCD Flat Panel Monitor
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
373 people viewed this question
Alun Cox
David Payne
David Payne
