Question about Whirlpool Duet GHW9150P Front Load Washer
It flashes F 70 and sometimes will not powere up as if the door is not closed when it is.
    Guru:
  • 1,738 Answers
Your door locking mechanism is bad.
Posted on Dec 12, 2009
Dome lights wont go off
Check your door switches, sometimes these go out.They are what your door pushes in to let light know door is closed.Either up front by the hinges or near the catch at the back.
Apr 07, 2014 | Metra TurboWires 70-6509 for Jeep Grand...
I have two Chamberlain LiftMater Professional garage door openers that are less than 5 years old. One unit works fine; but the other recently developed a problem where the door does not close properly. ...
switch out the motor units or use a simple hand held "spring scale" to see if the resistance on the two doors is similar. My bet is that something it binding.
is the unit that is not working used more or less often than the one that is working?
Nov 28, 2010 | Garden
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Garage door will inconsistenly not close
It is normal for that LED by the learn button to flash randomly. It can also flash a code to help with diagnosis. The codes are 1 to 6 flashes followed by a pause and then repeats. A rapid flash is a sign it is receiving a radio signal but not necessarily the correct one to operate the door. If when your door doesn't close properly the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. The sensor must be pointed at one another and sometimes can be off just a hair and will cause intermittent problems. A slight tweaking of the sensors will cure this problem. The 'down force' adjustment can be set too low and cause the door not to close sometimes. This can be increased to overcome this problem. This problem will not cause the main light to flash. The other possibility is the RPM sensor. This is the printed circuit board that senses when the door runs into something. I have never seen one intermittent but that doesn't mean it's not possible. I hope this helps you.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Power door lock will not lock and unlock
Door lock actuator, about $70 for the part at a Canadian dealership. I've had all except the driver door one fail now. Not impressed, Acura!
Jul 27, 2008 | Acura MDX Cars & Trucks
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
