Question about Garmin nuvi 255W GPS Receiver
HI - my Garmin nuvi will not turn on even after a 15 nin charge. I switch it 'on' - it displays 'GARMIN', beeps twice then turns off. Any suggestions?
    Guru:
  • 1,738 Answers
Battery is dead. You have to buy a new battery for your garmin. You can either buy from garmin website or a third party website. Be-careful before you do buy, because they will sell refurbish.
Posted on Dec 12, 2009
Garmin nuvi 255w flashes on & off
I did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars
Apr 02, 2013 | Garmin nuvi GPS
Touchscreen on a Garmin nuvi 1350 doesn't work
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Mar 29, 2013 | Garmin nuvi GPS
What do I use to hook my gps to the pc, to update it
You will need a USB cable to make this connection.
Any USB generic charger will work. I used on my Garmin the Motorola cellphone USB cable.
The procedure is like this:
Connect, start Garmin Nuvi and disconnect; then reinsert the USB plug when your Nuvi model number is displayed at the bottom of the screen. You can even charge your Garmin this way. To reduce the charging time follow these steps:
# change the display brightness to less than 25%
# turn off the Garmin device.
Mar 04, 2011 | Garmin nuvi 255W GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
I try turning it on. The GARMIN screen comes on, then after two seconds it beeps twice and turns off. How do I fix this?
If this is doing this only when not plugged into the power supply then try a plugging it in to charge it up for a couple of hours before testing again. Otherwise, try a reset (usually a small hole underneath that needs to be pushed in with a thin pointy object such as a toothpick.
Otherwise otherwise try a software reinstall. Usually obtained from Garmin.com and install it using the USB cable and garmin PC software.
Good luck.
Nov 22, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
I have a garmin 265w that shut off by itself and will not turn o
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
I can help you reset and fix your Garmin Nuvi 265W.
There are three steps to take to get your Nuvi 265W running like new:
I hope that helps.
Nuvi 265W Manuals here.
Feb 02, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Without plugged in my garmin nuvi 200 will not work
That means that you have to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
NEW Garmin 205W Use of Apple Mac USB for charging Causes malfunct
Hold the power button to the left for approximately 15 seconds, then release it. It should reset the unit and turn ON. It happened to me before and it worked.
Dec 08, 2008 | Garmin nuvi 205W GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
385 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
