Electric kitchen aid double oven gives eo message
    President:
  • 1,891 Answers
There should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Posted on Dec 12, 2009
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Message EO F2 on the panel
EO and F2 means you have a shorted keypad. Or the oven temp is too high. The cheapest route to go is to replace the oven temp sensor first. If you give me the model number i can get the part number. If the oven temp sensor doesnt fix the problem You have to replace the electronic control. Check to see if there is a y near the end of your model number. if there is then it is most likely just the sensor. If there is no y then it is most likely the electronic control. (this is what my code chart says) But you can try the oven temp sensor anyway. It may fix it.
Nov 21, 2008 | KitchenAid KERA205P Electric Kitchen Range
Open Questions:
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
