Question about Moen Plumbing
Need to replace cartridge in single lever moen kitchen faucet .Walk me through the process.
    President:
  • 3,085 Answers
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
SOURCE:
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Re: Moen single-lever kitchen faucet like the 7100. When I replace the lever, it only goes up. I can't get it to go down. I'm pretty sure the cartridge is in right, with the U-clip and the other screw-on...
    The water supply should have no bearing on the working motion of the faucet cartridge or handle. On both models of Moen faucet, the handle needs to be hooked under the cartridge's top cam bearing. It is a bit tricky sometimes. Here's the parts view for 7300 and 7310 Moen Kitchen faucet. Parts view for 7100 Moen.
    If you need further assistance please let us know.
    Sep 16, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
    I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
    Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    1,230 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Thomas F. Schneider
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
