Question about LG enV3 VX9200 Cell Phone
Cant charge phone from my pc.
Trying to unlock phone. I have imei number, nck and spk but still cant do it. please help
Contact your previous cell phone provider on this phone and they can help you unlock this, there may be a small charge.
Dec 20, 2016 | ZTE Cell Phones
My phone is restarting after welcome screen. i cant update it cause i cant set the usb mode to pc suite and i cant restore settings. i tried nokia sotware updater, jaf nothing works they cant detect p
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 25, 2012 | Cell Phones
My nokia e52 cant charge and cant connect to pc. when i connect on usb she dont display me notting.
Install the necessary drivers and if still it don't work then,uninstall your pc suite and then reinstall it from your cd which was given during purchase and don't run anything in the background while installation and restart your pc after installation and then connect your phone to pc and then,also,check whether you have selected pc suite,under connection settings in phone..Then when you connect you can see your phone is connected...Have a nice day...
Feb 13, 2011 | Nokia E52 Smartphone
Please help
if you cant charge handy with charger,you can not use usb to charge.problem is a damaged conector for charging.must be fixed or changed in service.
Dec 05, 2009 | Samsung SGH-D900 Cellular Phone
Cant charge my htc p3300 phone
you must have disabled that option, go to settings select power and there will be an option ie. "when device is turned on" deselect it.
Aug 03, 2009 | HTC Touch Viva Cell Phone
My phones charging socket doesnt work!
you will need to take the phone to a mobile service center and have them replaced the charging port.....
Oct 07, 2008 | Samsung SGH-E900 Cellular Phone
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
Hi ,verizon pocket pc 6700 bad charging usb connection on phone
i have an AUDIOVOX VERIZON POCKET PC and serusosly I cant turn on the phone i put it on charge the green light flashes but i cant even power the whole phone on is ther anyone that can help me thanks
Sep 06, 2008 | Audiovox Computers & Internet
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
LG enV3 VX9200 Cell Phone Logo
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
