Question about Linksys Wireless-N WRT150N Router
I tried port forwarding and checked with a port forwarding tool and in comes up not being forwarded.... help?
    Guru:
  • 1,738 Answers
Make sure you windows firewall program or another program is not blocking it as well. If you are using another firewall you can tell to allow it without shutting down the progrram.
Posted on Dec 12, 2009
I am trying to open up port 25565 on my NETGEAR WNDR3300 dual band router. I access my default gateway through an internet browser and forward the port correctly, but when I go to a website to check to...
If you have ports in your router , even it it shows that the port is closed in http://www.yougetsignal.com/tools/open-ports/ if the application for which you have forwarded the ports works then no issue with that. If it doesn't work then we need to know who is your internet service provider , because its is a DSL connection which works in the Dynamic configuration then its obvious the port will not be forwarded beacuse of double NAT. Inorder to fix this you have to bridge the DSL modem .
Thanks & Regards,
Prema.
Jan 06, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Hi there, Im trying to port forward my d link
Try putting your computer ip in DMZ, although this may bring some security risks.
May 17, 2010 | Computers & Internet
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
Forward ports in linksys wrt45g so magicjack will work
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Oct 05, 2008 | Enterasys Distributed Forwarding Engine...
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Accessing echolink nodes
Please go to the following website and check the port numbers that you have forwarded. Some wireless routers do have issues forwarding ports. http://www.t1shopper.com/tools/port-scanner/ Also, before you use this tool, make sure ICMP is not blocked in the router's settings; if it is blocked all ports would show blocked. Try this and let me know the results. Cheers
May 14, 2007 | Cnet CWR-500 Wireless Router
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
