Question about Cooktops
Does not make ice
Ice maker is not making ice
    President:
  • 1,891 Answers
There a lot of could be's / so look for a frozen inlet tube wher it dumps into tray / a bad water valve./ freezer tempt must be below 15 deg. for ice maker to cycle . and most common the ice maker itself may be bad . mm . if more info is needed and thes didn't help nee model & brand .. mm
Posted on Dec 12, 2009
I need to find the instruction manual for this product - any ideas?
Usually you can just Google in the make, model and any other details plus the word Support. In the list Google gives, look for one with the makers website.
If not choose the most promising
Nov 15, 2015 | Cooktops
G E Select ice maker has stopped making ice
First, check the filter and make sure it isn't clogged. Second, check the water line and more importantly, the valve that feeds the water to the fridge. It should be 1/4'' line and usually has a saddle valve installed off another larger cold water line. Saddle valves have a tendency to rust and clog. these are simple fixes, generally. IF all these check out OK, Check the water valve inside of the fridge, where water line comes in..Hope this solves your problem.Good luck DW
May 11, 2014 | GE Ribbon Module for Select-Top Modular...
Ice maker line freezes
You could try fitting a non return valve close to the ice maker.
Apr 21, 2014 | Frigidare PLGC36S9EC 36 in. Portable Gas...
Blanco Blanco BCM6X Built-in Coffee Maker manualmanuals
My Blanco coffee machine (BCM 6 X) does not heat or froath milk
Jan 03, 2014 | Cooktops
I have had the KFIS29PBMS french door refrigerator for 2 days and the freezer drawer on the bottom right side if full of ice/frost on the outside of the drawer. What is wrong? What can I do to fix...
The seal on the door is not making contact with the fridge. Take a hair dryer on moderate heat setting close the door and heat up the seal where the frost is until it gets flexible and makes contact with the fridge for a good seal. Should happen in about 30-45 seconds. I had the same problem, waited around all day for a service tech to come and he did this in a minute. I was not happy and was like why did you not just tell me to do that over the phone.
Jun 15, 2013 | KitchenAid KFIS29PBMS
Numbers have rubbed off oven prima
Welp, you're gonna have to get yourself a cheapo oven thermometer and relabel (sharpie or label maker, or tiny paint pen). Most ovens aren't very accurate according to their labels anyway, so you'll have to experiment with the thermometer and some labeling. If ya want to be slick, you can get some clear contact paper or similar, tape out some basic temps, then print out a label with them all. But a plain old label maker will probably work fine.
Feb 18, 2013 | Cooktops
Temp alarm chimes can't find control pad to turn it off
look on the internet they might help you , type in the info you have about it.
Nov 10, 2012 | Maytag MBF1958XES - 30% E-Star, 19 Cu....
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
The element I use the most stopped heating and my ice maker stopped making ice.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 26, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Cooktops Logo
50 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
