Passlock I reset.
1. Attempt to start the car, let it stall, but DO NOT turn the key off! Leave it in RUN.
2. Wait 10 minutes or until the Theft Sys light glows steady instead of blinking.
3. Do not turn the key off, but start it immediately.
4. This should reset your Passlock system.
PASSLOCK I or II DISABLEMENT
The following is a procedure to disable Passlock I or II Systems for vehicles
in which remote start/stop system installations are required. This procedure
is required because a remote start system will not function with the current
Theft Deterrent System (Passlock) which is included on many 1996 and up GM
vehicles.
Please note that this modification is intended to be used only in conjunction
with the installation of a remote start/stop system and does not provide a
procedure to install a remote start/stop system.
CAUSE
If an attempt is made to start a vehicle by a means other than a key rotation
in the ignition switch, the Body Control Module (BCM) will interpret this
start as a vehicle theft and disable the fuel injectors.
CORRECTION
A minor wiring modification may be made to allow the vehicle to be started
remotely. This modification includes adding a switch to allow the customer to
select ?ON? to allow remote starting or ?OFF? for normal Passlock operation.
CAUTION: When this modification is performed and the switch is set to the ON
position, the theft deterrent feature will be disabled. When the theft
deterrent is disabled the SECURITY/THEFT SYSTEM telltale will light up
indicating that the theft deterrent system is NOT functioning.
PASSLOCK MODIFICATION
Refer to appropriate GM service manuals and/or SVMQP Electrical Guideline
Manual for instruction on splicing and electrical connections.
1. Select a suitable on-off switch (see note below) which will be used to
disable/
enable the Passlock System. Mount the switch in a location such that it is
accessible to the driver and will not interfere with normal vehicle operation.
NOTE: This is an extremely low current circuit (approx. 7mA), it is therefore
very important that a high quality, low energy, fast acting switch be
utilized for this application.
2. Turn the ignition switch to the OFF position.
3. Locate the Main Ignition Switch Harness in the Column. GM's Passlock
System wires exit the Ignition Switch Tumbler together and then join with the
Main Ignition Switch Harness. (See http://www.bulldogsecurity.com/ or
http://64.85.6.118/diagrams/diagrams.asp and select your Make, Model and
Year for wire colors and clues on the quickest way to access these wires.)
4. Locate the Yellow Passlock Data Wire which is included in a bundle of
three tiny (20 GA) wires wrapped in friction tape.
Cut this wire and splice a 0.5mm2 (20 GA) yellow wire to each end of the cut
wire.
Keep wire length to a minimum. Route modification wires clear of moving parts.
Connect the yellow wires to the switch such that the contacts are OPEN when
the switch is in the ON position.
5. Turn modification switch to the OFF postion (contacts closed).
6. Start vehicle to verify normal operation. If engine ?cranks but will not
start"
recheck the switch position (contacts should be closed), wire connectors and
modification wiring.
SWITCH OPERATION
To enable remote start:
Start the engine with the ignition key (modification switch must be in the
OFF
position). Turn modification switch to the ON position (contacts open). The
SECURITY/THEFT SYSTEM Telltale will light up indicating that the Passlock
System is inoperative.
Once the SECURITY/THEFT SYSTEM telltale has been on for at least 5 seconds
the vehicle can be turned off and then remotely started.
To disable remote start:
The Passlock System can be reactivated by turning the modification switch OFF
(contacts closed). Vehicle can either be running or off when this is done.
Please note that the VCM/PCM will record Diagnostic Trouble Codes (DTCs)
related to the security system when the modification switch is in the ON
position (circuit open). This is due to the way that the VCM/PCM interprets
this condition.
NOTICE
Any condition which removes battery power from the Vehicle Control
Module/Powertrain Control Module (VCM/PCM) (e.g. dead battery, disconnected
harness connectors, etc.) will prevent the vehicle from being restarted. If
the engine exhibits a ?cranks but will not start? symptom, place the
modification switch in the OFF (contacts closed) position. This will
reactivate the Passlock System and allow the vehicle to be started with the
ignition key
SOURCE: pass key fault light comes on and car want strat.
i had the same prob in my 94 the ignition cylinder is bad change the ignition and i swear it will work perfect
SOURCE: massage, pass key fault
there is a micro chip inside the head of the igntion key, when you put the key in the igntion the sensor inside the steering colunm will read the resistance of the micro-chip. If there is a match the engine will start. If for some reason the sensor will not read the micro chip the system will think some is stealing the car. I would try another key 1st, if this persist, the module will need to be replaced. Start with a new key, its cheaper.
You'll need to go a GM store parts departement with the old key, drivers license & registration for the dealer to cut a new key.
SOURCE: the pass key fault light is on and my car wont
Mine did the same thing. I had to replace the ignition switch and haven't had a problem since. The inside wears out and don't make a conection to the chip in your key.
SOURCE: 95 chevy caprice pass key fault.
WELL I HAD THE SAME PROB. ON A 95 CHEVY CAPRICE.I REMOVED THE IGNITION AND THE WIRE WAS BROKE.WHEN U TURN THE KEY THE PASS KEY WIRE TURNS WITH THE IGNITION,WHAT A FAULTY DESIGN.ANY HOW BUY A NEW IGNITION AND KEY THAT SHOULD SOLVE THE PROB. GOOD LUCK
SOURCE: pass key fault is brinking
So the Security light is on or flashing in your vehicle and you are looking at 1 of 3 things. Either the vehicle won't crank over and start, It cranks but dies in a few seconds, or your vehicle shuts off while driving scaring the **** out of you. You have now experienced GM's worst security system ever created. GM's security, also known as Passlock Passkey or Vats.
There are 3 parts in this system:
1.The CHIPKEY
Normally a black resister chip in key which "communicates" to the lock cylinder. Sometimes is hidden in the plastic part of keys in new models. Same concept, might say PK1 PK2 PK3 PL or something similar to that. The newer ones work on frequency. Same thing tho.
2.The LOCK CYLINDER
Inside there are pins that read the chip in the key or the part that reads the frequency on new models. This then "communicates" to the TDM)
3.The TDM
Theft Deterrant Module-Sometimes called the "computer" or "brain". This is the part that sends the signal (**NOTE**) to your car and allows your car to start or continue running depending on your type of system.
If any of these parts are not communicating properly, your SECURITY light will come on and shut down your vehicle. The idea being, that without the chipped key or FOB key, the vehicle wont start and cant be "hotwired" or stolen. Pretty nice when working, but these systems are flawed and the average life is 6-10 years. Every single aspect of this system is expensive to replace and can only be worked on by "authorized" GM service men with out voiding warrenty. Most garages dont even touch them and if they do,
they will sell you every part they can before "fixing" the problem
*QUICK FIX TRICKS*
1st trick
Try a spare key that is newer or used less. The pins wear down with use and so do the keys causing the security to fail.
2nd trick
(if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my Buick for more than a year. Remember this is a temporary fix... If its shutting down while running, I'm sorry I have no quick fix...
*PERMINANT FIX*
Well since the lifespan of these systems are so short, and are extremely expensive to fix, and in my opinion far worse of a threat to owners than theives, my only perminant suggestion is to eliminate it completely. After a year of 10 minute tricks and a "key bypass" that lasted 2 months. I have only one good suggestion. After surfing the web for hours thru forums and websites i came across http://newrockies.com/passkey to the starter or injectors and so on. Thus eliminating the ENTIRE system COMPLETELY. I came upon a fork in my road. A TDM for $600 in my $1000 car or the $200 bypass. Or throw my car away. Lets say i now drive a Buick with the chip ripped out of the key and the TDM sitting in my glovebox for show
and tell. If you have any questions or anything else. Comment on this post
and i'll get an E-mail to reply to you. If you do choose to buy the bypass,
i have pictures of what a TDM looks like and will definately help you when
installing the newrockies bypass. Good luck
Here is a list of known effected cars that can be fixed with the
newrockies bypass. This is the same list from the site and updates
frequently.
Trucks
GMC/Chevy
1998-2006 S10/T10/Sonoma
/Blazer/Jimmy
1998-2007 Suburban/Avalanche
/Tahoe/Yukon
1998-2006 Sierra/Silverado
2002-2008 Trailblazer
2003-2006 SSR
1998-2006 C1500/C2500/C3500
1998-2006 K1500/K2500/K3500
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1994-2003 Grand Prix
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1994-1998 Trans Sports
1988-1999 Bonneville
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-1996 Century
1993-1996 Regal
1982-1999 LeSabre
1991-1996 Park Avenue / Ultra
1994-1996 Roadmaster
1991-1996 Roadmaster Estate Wagon
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
1982-1990 Electra (all models)
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1994-1999 Eighty-Eight
1991-1996 Nighty-Eight
1998-2002 Intrigue
1990-1992 Toronado
1994-1997 Cutlass Supreme
1997-1999 Cutlass
1997-1999 LSS/Regency
1997-1999 Silhouette
1991-1996 Custom Cruiser
Chevrolet/GMC
1998-2005 Astro/Safari
1998-2008 Envoy
2005-2006 Equinox
1998-2007 Savana/Express
1995-2005 Monte Carlo
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-1991 Corvette
1994-1996 Caprice/Caprice Wagon
1995-1996 Impala SS
2000-2005 Impala
1997-2005 Malibu Classic
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1985-1996 Fleetwood Brougham
1992-1995 Seville
1992-1995 SLS/STS
1985-1995 Deville
1994-1995 Deville Concours
1988-1995 ElDorado
1994-1995 ElDorado Touring
1999-2007 Escalade
Saturn
2000 LS/LS1/LS2/LW1/LW2
2001-2002 L100/LW100
2001-2003 L200/LW200
2001-2005 L300/LW300
2004-2005 L-Series
2002-2008 VUE
1996-2002 SL/SL1/SL2
1996-2002 SC1/SC2
1996-2002 SW1/SW2
