Intermittantly my set pops and looses sync lock when viewing an off air hd signal. The trouble code flashes 2 1, which indicates x-ray protection problem. I turn the set off and back on and trouble is cleared for a while. If I'm viewing a component input, the set goes to dark gray with no picture or sound. I have performed a master reset on the front panel but without favorable results.
  • 2 more comments
  • dfrancois01 Dec 13, 2009
    From my service manual I found the FBT T5A51, there is no mention of a HV tripler. Is the tripler part of the FBT?
    It's a Mitsubishi WS-55813
    Do you have any detailed instructions for replacing that part?
    Don
  • dfrancois01 Dec 14, 2009
    I think the pop that I hear is coming from the speakers.
    The problem is that sometimes it will be several days before it happens, then other times it might be only an hour or two. I'm beginning to think it's associated with the humidity in the house.
    These kinds of problems are difficult. The FBT is $150 part, you hate to just guess.
    Perhaps you might like this one;
    "A problem is a solution in disguise".
  • dfrancois01 Dec 17, 2009
    Thank you for your prompt replies and assistance.
    I haven't had any problems with the set going off for the last three weeks. I'm beginning to think that it's associated with the humidity in the house and the outside temperature. It's been quite cold during this time.
    Does this give you any clue as to what's happening in case it starts failing again in the future?
    Don
  • 5,138 Answers
FBT flyback transfomer or the high voltage trippler.
Posted on Dec 12, 2009
  • 2 more comments
  • ladywinn
    ladywinn Dec 13, 2009
    What is your Brand Name and Model number of your TV?
  • ladywinn
    ladywinn Dec 14, 2009
    This model may not have Trippler , Turn tv on with back off and see what pops could be anode button on one of the Tubes leaking out high voltage.
  • ladywinn
    Ive seen times when anode buttons on Tubes get mositure around them and they will pop due to that,but if it begins to do it alot you really need to silicon around anode buttons But be very carefull they do hold a charge High voltage. theirs a high voltage spray that you can use to spray on them Call Mats Electronics ask them corronan ? I know thats not spelled correctly 1-800-628-1118 ask them to also send you a catalog they have alot of Good stuff!
  • ladywinn
    ladywinn Dec 17, 2009
    I dont think I would really worry about it Moisture does alot of strange things to a TV if you had a high voltage leak it would have only gotten worser.
Keeps throwing up trouble codes p1506,p1151,p0302,p0171
Definition of Diagnostic Trouble Code P1506 Audi: Closed Throttle Position Switch Does Not Open/Short to Ground BMW: Idle-Speed Control Valve Opening Solenoid Control Circuit Signal High Ford: Idle Air Control Overspeed Error (see P0507) Jaguar: Idle Air Control System RPM Lower Than Expected - B Bank Kia: IAC Valve Opening Coil Voltage High Lincoln: Idle Air Control Overspeed Error (see P0507) Mazda: Idle Air Control Overspeed Error Mercury: Idle Air Control Overspeed Error (see P0507) Porsche: Throttle Jacking Unit Lower Mechanical Stop, Signal Implausible Volkswagen: Closed Throttle Position Switch Does Not Open/Short to Ground Volvo: IAC Valve Opening Signal
Definition of Diagnostic Trouble Code P1151 Audi: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Jaguar: Lack of H02S-21 switch, sensor indicates lean Land Rover: Lambda control limit bank 2.Implausible signal/condition Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean Subaru: HO2S-12 Heater Circuit High Input Toyota: Coolant Path Clog Up for Coolant Heat Storage System Volkswagen: Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
Definition of Diagnostic Trouble Code P0302 Category: Powertrain Definition: Cylinder 2 Misfire DetectedNote: This definition of P0302 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0171 Category: Powertrain Definition: System Too Lean Bank 1Note: This definition of P0171 is applied to all manufacturers
Jun 17, 2015 | Cars & Trucks
What does a blinking orange light on 65" Mitsubishi dlp rear projection TV mean?
Self Diagnostics
The V18 Chassis features Self Diagnostics to aid in troubleshooting problems that may cause the set to
automatically turn off or "shut down." The "Timer/Power ON LED" provides an indication of the sets operation,
and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
To activate the Error Code Mode, while the set is OFF, press the front panel "INPUT" and "MENU" buttons
at the same time and hold for 5 seconds. The LED will flash denoting a two digit Error Code.
Note: The Front Panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occurred.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
Jul 24, 2014 | Mitsubishi WS-65809 65" Rear Projection...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
My TV shuts off as soon as I turn it on...What is causing it to do this??
When it shuts off. Try doing what's called a self-diagnostic test. As soon as the television shuts try these steps.
Pressing on the front panel's 'INPUT' and 'MENU' buttons at the same time, and holding for 5 seconds, activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
-The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
-The flashing then pauses for approximately 1/2 second.
-The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
-The Error Code is repeated a total of 5 times.
-Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
Self Diagnostic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Apr 08, 2010 | Haier 20" TV/DVD Combo
Air bag Indicator flashed and than stays on
If the only code 52 is flashing then system is ok and just needs to be cleared.Look behind the glove box and find the gray 2 wire connector.It will be on the left side behind the glove box and follow the proceedure below. Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ±two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic Service Connector located underneath the glove compartment containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (T/R) to Circuit 57 (BK). Diagnostic trouble code is now cleared from NVM. Next highest priority diagnostic trouble code stored in NVM (if one exists) will begin flashing
Mar 03, 2009 | 1994 Ford Mustang
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Feb 09, 2009 | 1995 Lincoln Town Car
ABS light
It is picking up a signal from one of the wheel sensors probably.
Go here to read files on ABS issues
http://autos.groups.yahoo.com/group/villagerquest/
  • Anti-Lock Brake Warning Indicator Always On
  • Fuse(s).
  • Circuit.
  • Hydraulic solenoid relay.
  • Hydraulic pump motor relay.
  • Brake anti-lock sensor(s).
  • Hydraulic anti-lock actuator assembly.
  • Anti-lock brake control module.
  • GO to ABS Quick Test .
QT5 PERFORM ABS TROUBLE CODE RETRIEVAL
  • Key OFF.
  • Jump Pin 4 of the data link connector to ground.
  • Key ON.
  • Observe the anti-lock brake warning indicator.
NOTE: The first code to flash will be the start code (12). Also, each code is repeated three times before proceeding to the next trouble code.
Does the anti-lock brake warning indicator flash codes? Yes No RECORD code(s). GO to the following ABS Trouble Code Identification Chart in this section and PERFORM Pinpoint Test specified for first code retrieved. If indicator is illuminated constantly, GO to Pinpoint Test D1 . If indicator is not illuminated, GO to Pinpoint Test A1 .
Jan 02, 2009 | 1993 Mercury Villager
Will not turn on
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
times.
Self Diagnosic Code Description
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My tv willnot turn on
times.
Televison & Video Logo
Top Televison & Video Experts
