Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
F300E powers up in purge mode, but shuts off when heating
Ok, here is the scenario - My F300E does seem to power on (no light, no snapping with test button) when my HVAC system is running in heat mode. I have a multi-zone system, and when I reboot the Honeywell zone management system and the whole thing goes into "purge" mode, the F300E powers right up and works normally...until the system kicks back into heat mode and ti shuts off instantly.
Any clues on that one? I am under the impression that the unit turns on and off based on the airflow sensor, so why would it care what mode the system is running in as long as the air is flowing through?
I have repeated the process multiple times to be certain it was reproducable behavior. I also cleaned all the contacts and made sure the cells were in good shape before trying out the restarts and all of that. I had noticed a huge increase in dust in the house over the last few weeks and went to check on it today when I found the problem.
  • 22 Answers
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Posted on Jan 20, 2010
SOURCE:
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
Dear Expert, I do hear scary sound like a electric spark once in a while, and then stop. Should I turn off the switch? Thank you.
Arcing (snapping) seems too frequent
1. If the electronic cell(s) are wet from washing, turn the air cleaner off for two to
three hours.
2. Check the cell(s) for broken ionizer wires or bent plates. Repair if necessary.
3. Wash cell(s) and prefilter(s) if dirty.
Sep 28, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Power light not coming staying on...
pull the cells out and run the filter without them. If the light stays solid then you most likely have a simple short in one of the cells. Install one cell at a time, push it all the way back, close the door, turn on the fan. IF the light stays solid, that cell is fine. If the light flickers or goes out, the most common cause is a bent fin.
Look at the cells and see if any cells are touching or are too close, this will cause your problem.. Simply bend the cells to get even spacing and you should be ok.
Jul 15, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
F50E New Power Supply Arcing
check the fins on both cells for even spacing on the fins. If the fins are bent a little, this will cause your arcing.
Pull both cells out and reinsert them one at a time. Keep the cell all the way to the front or all the way to the back so it makes contact with the power supply.
The cell that has bent fins will continue arcing. Good luck.
Nov 13, 2006 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
260 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Pierre Laplante
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
