Question about Fahrenheat (FFH1614) Wall Mounted Panel Heater
Installation of Fahrenheat wall heater
I need to know if this unit can be mounted with the TOP being the right-hand side instead of the top.
Not according to manual it can cause fire hazards
Posted on Dec 28, 2008
Http://www.marleymeh.com/develop/prod_pdf/instructs/5200-2638-000.pdf
Posted on Sep 09, 2008
6ya staff
SOURCE:
How can I change language to English?
Hopefully, using Google translate, this will help you:
Click arrow down button right hand side top menu
Configura??es - or similar option?
Then click Lingua(?) on left hand side
Top option is the Language, click editar(?)
Choose Ingles
Mar 31, 2016 | Facebook Computers & Internet
Knocking noise from front right end on 98' camry. 99,000 miles, and I am the second owner. first owner kept up great maintanence. I have been advised from large national chain that both front end quick...
I think you should make quite certain at the mechanics' that it is the struts and mounts knocking, and not the lower main ball joints. However worn strut top mounts are the most likely cause.
You don't say where you are but in the US $1000 should get you new struts and mounts both sides, albeit not a top name brand, and a necessary wheel alignment also.
You should not just replace only one side as that will degrade the handling and steering of the car.
Aug 25, 2017 | 1998 Toyota Camry
GE refrigerator chilled water has mildew taste
change the water filter usually located in the upper right hand corner of the refrigerator compartment on side x sides,if top mount freezer it can be about anywhere inside the unit except freezer compartment
May 11, 2012 | GE Refrigerators
I have no way to connect to the granite counter top. Can it be mounted to the side cabinets?
Need prefix for model number. Need complete model number. I believe that the numbers that you have given are stock numbers from your user manual. Kenmore can be several different manufacturers. Some brands have kits to mount unit from the sides using brackets at the top. If stainless steel tub, look for removable plastic caps on the right and left sides of unit. These holes would be used for installing bolts into cabinet. If plastic tub and no kits are available holes can be drilled into sides to secure unit to cabinet. As long as heads of bolts(screws) are flush to allow door closing, unit will not leak because of tub(door gasket.
Feb 15, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I havde a top load washer . sometimes it doesnt start the wash cycle because its not recognizing that the top is closed. swe have to press on it most of the time for it to start .. but someetimes it stilll...
The lid switch is mounted to the top on the right hand side. First unplug unit remove the control panel one screw in each back of each end panel ,remove main retaining clips and pivot entire washer housing to gain access to internal parts..Also check hinge screws (2 small phillips head) on each side of lid ..the arm on the right side actuates the lid switch if loose could cause intermittent operation
Nov 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I just bought my gps but i dont know how you turn on it on? and what is the circle disk for?and where should i connect the handle at? i dont get it...
The unit has a slide switch on the side. If you are asking how to mount the unit, it came with a bracket that snaps on (there are indentations in top and bottom where it hooks in). Then you pop the ball mount into the receptacle on the back. The circle disc to which you refer is for PERMANENT dash mounting. It has double sided tape that sticks to the dash. You can then use the suction mount on the disc instead of the windshield. I hope this helps.
Oct 01, 2010 | Garmin nuvi 250W GPS Receiver
Marlin .308 with leopold scope. I've moved the adjustment all the way to the left but still shooting to the right of center??? Could the scope mounting holes on the top of the rifle be crooked? Crooked...
marlin rifles have a right hand twist in them,, they all shoot to the right,,,if you pack out the scope mount with a strip of old 35mm film on the right hand side of the scope body and reclamp the scope you should have the cross hair more to the right side
Oct 08, 2009 | Optics
Dryer works fine, washer fills up, then does nothing more
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the top cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (along the right hand side tub rim). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Washer Top and Lid" heading. The lid switch is listed as item number 22 (part #3355806) and the lid strike will be listed as item number 16 (part #358684). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory.
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know. You should be able to access the lid switch on your model washer by the following steps:
1. Unplug the appliance.
2. Insert a putty knife into the seam where the top of the washer meets the front panel, about 2 inches in from each side.
3. Push in on the release tabs while lifting on the washer top. The top panel and lid should lift up. The lid switch should be mounted under the top panel on the right hand side.
4. Locate the lid switch connector and unplug it.
5. Remove the the mounting screws that hold the switch in place, and remove the wiring harness from the mounting clips.
6. Reinstall new switch using the above steps in reverse order.
I hope you find this information helpful. Let me know if you require additional assistance.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Oct 04, 2008 | Washing Machines
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
How to reset tom tom 910
the reset hole is hard to find... If you are looking at the back of the unit, it is in the upper right hand side of the liitle plastic protrusion at the top of the semi-circular opening above where you can see the exposed circuit board.
Mar 27, 2008 | Tomtom GO 910 GPS Receiver
Fahrenheat (FFH1614) Wall Mounted Panel Heater Logo
191 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
