Question about Harman Kardon AVR 325 Receiver
Shutdown during exciting audio
I have a harmon kardon AVR 325 and for some reason it will just turn off during exciting areas of movies and TV. For example, whenever there are a lot of explosions and stuff the sound will just turn off. The volume isn't even all that high, so I don't know what could be causing this. Any suggestions?
  • Tri-3 Apr 11, 2008
    I have the same problem. I went online and purchased the service manual. It has a fix for this problem that involves removing connectors on the Bias/Fan cable and soldering directly to the PCB's. They must have a connection issue that gets worse with heat.
    Then required to check the bias adjustment on each channel. A good tech should be able to handle this fix.
I have the same problem also. Customer service told me to double check all my cable wires to make sure there is no short. Heck I just went ahead and unplugged all the speaker wires and then it was fine. I replaced all speaker wires and it worked for a couple days but its starting up again. i did the hard reset like the manual told me to do but the same problem.
Thats what customer support told me to do. They said it could be because its going into a safe mode. Mine is just shutting down no matter what sound is coming out of the tv or movie.
Posted on Apr 02, 2008
How do to connect tv from AVR
audio out from tv to audio in on the avr
Apr 19, 2015 | Harmon Kardon Harman Kardon AVR 235...
No sound from tv to speakers
i assume you are hooking up from tv to receiver with an optical cable? Check the settings on your tv. Most tv's have a setting to turn on/off the optical audio output
Apr 21, 2014 | Harmon Kardon Harman Kardon Avr-20 Ii...
Harman kardon avr 1500
Try using the RCA outputs once and see if that works..One other thing don't use the phono input on the receiver as it could damage the amplifier
Feb 16, 2018 | Audio Players & Recorders
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
Hi, I have a Harmon Kardon Model No. AVR 325 that keeps clipping. When I push the power button the display turns off like a second after I push power. Seems like its a easy fix. Nothing if fried visually...
it sounds like Amp burned, but not all burn parts you can see, you have to measure them by DMM. I guess at least one AMP transistor shorted. you can check SPK terminals by DMM DC, it can be easy to find different with other one
Mar 19, 2011 | Harman Kardon AVR 325 Receiver
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
check the wattage of the speakers, they could be drawing too many watts from your amplifier, if you plug in a speaker that's more than the channel, it could harm your amp.
for example a 200 watt stereo, with 4 channels that equals 50 watts per speaker.
Hope this helps you out
Apr 01, 2008 | Audio Players & Recorders
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 325 Receiver Logo
270 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
