Question about Frigidaire Washing Machines
My washer will not spin all of the water out all of the time. it shows E20 and stops, we replaced the door latch before and that worked but this time it did not, but will spin out if i reset on spin/drain cycle. could this be in the cycle knob or timer?
    Guru:
  • 1,738 Answers
It is the timer.
Posted on Dec 12, 2009
SOURCE:
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
hope this will help you out
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Front load Washer will not do a final spin
my front load washer wont final spin and show me e20 code
Aug 03, 2009 | Frigidaire ATF6000ES Front Load Washer
No spin cycle, stopped running
Hello, sounds like this is going to be a pump issue, take the lower panel on the front off the machine, there you should see something that resembles a gas cap like on your car. It will be located some where near your pump...Unscrew this cap making sure you have some towels handy to mop up the water that runs out. Once you have pulled out the cap attached you should find a filter cage. You will likely find a bunch of debris,coins,lint and other stuff blocking the pump. Replace this cap or filter and plug machine in and try again, You should be good to go. If this does not fix the problem you are going to need to replace the pump. p.s not sure why you are looking to replace the door latch since you mention the machine is not spinning. The door latch has nothing to do with the spin other then locking. Good Luck!! if you have any toher questions or concerns please feel free to comment again. Mike
Jul 20, 2009 | Frigidaire GLTF2940E Front Load Washer
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
The machine runs until the spin cycle then stops
That means that you need to have the door latch replaced, a bad door sensor is preventing the washer from spinning.
Try first unjamming the latch with a stick, like a pencil for example.
If that does not work, replace the door latch.
Mar 30, 2009 | Whirlpool AWM8163 Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
