Question about Car Audio & Video
How to hookup 9 inch Rear Boss Car replacement speakers in a 1995 Dodge Neon 4-door Sport auto? Any polarity concerns? Which wires go where?
  • jcw1956 Dec 12, 2009
    The first expert did not help very much!
    The speakers each have two male tangs (receptacles), one a litle bit wider than the other, but neither is designated as "hot" or ground, and neither is grounded to the speaker frame. Each female plug in the car has two lead wires connected to two sockets, and each female socket in the plug is of the same width. Possibly one of these leads wires is grounded to the car ground. (I'll have to get a multimeter and measure the resistance to ground while the radio is on.) Can I cut the lead wires from the female plugs in the car and connect them to the female plugs that came with the speakers without any concern as to which wire connects to the the wider female socket and which wire connects to the narrower female socket?
  • jcw1956 Dec 14, 2009
    Right on Jack.
  • 8,197 Answers
It really does not mater what wire you put on what male connection. All that you are doing is making a loop with the wire. there is no + or - side of a speaker. If you do not believe me you can hook it up one way turn on radio and lesion to the sound then switch the wires to see if the sound is any better. You will not here a deference. Also you can cut the wire and put on any connectors that you would like.
Good Luck
Posted on Dec 12, 2009
    Guru:
  • 773 Answers
You could get harnesses from best buy or a place that installs car audio.
they plug into the stock plugs so you don't have to cut them and they will only plug onto the correct tabs on the speakers.
That's the best way to do it. It costs a few dollars more by you won't be cutting wires.
If you insist on cutting the stock plugs off, use a digital multimeter to check which wire is positive and ground. Just turn on the radio and check each wire.
OR
On most speakers it will show you + and - next to each wire that on the speakers. You can see which wires would be + and -.
  • Don Reiman Dec 12, 2009
    Take a 9 volt battery and connect it to the tabs. It will either move out or in. when the speaker moves outward, what ever pole of the battery is on each tab is what polarity it is.
    Gee sorry I didn't help much. From professionally installing car stereos for a while, I just don't cut the stock wires ever. It causes problems. Especially if the care is leased or financed. You cannot modify vehicles like that when its leased or financed, so you just get into the habit of not cutting wires.
    The best way to do it, hands down is to purchase adapters for your car to speakers. Then it plugs right in with no cutting, and the tabs will only fit on the right tabs.
    As well there is usually a + and - stamped into the piece that holds the tabs.
2006 dodge dacota radio wiring harness
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
Dec 03, 2016 | 2006 Dodge Dakota
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
May 18, 2016 | Dodge Cars & Trucks
Hi i have a 95 buick lesabre i bought from a friend everything works great sides the radio i have an after market stereo jvc model no kd-g320 not sure witch color the antenna wire would be car has a power...
Antennae wire and other wires for the stock stereo are listed below:
1995 Buick LeSabre Stock Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Feb 19, 2015 | 1995 Buick LeSabre
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Trying 2 find door speaker size for a 1995 dodge ram van B2500 and rear speaker size also
according to crutchfield dot com----front door is 6 x 9.
rear doors says 6 x 9, as well.
hope this helps
Mar 19, 2010 | Car Audio & Video
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Jun 19, 2009 | 2005 Dodge Neon
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Need to get wiring diagrams
1988 Dodge Ram Charger Car Audio Wire Color Codes
Car Radio Ground Wire: Chassis
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6′ x 9′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Green
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
pls rate
Jun 23, 2008 | 1988 Dodge D-Series Pickups
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
