Question about Intel ASUS Pundit Celeron 2.0GHz Slim Computer System (SYSINTCMM03) Barebone
Manual I have an intel celeron 1100 mhz and would like to add memory. It currently has 384? in memory. What is the max it can accept?
  • 46 Answers
Check mb. documentation
Posted on Jan 28, 2008
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
851 MHz Celeron Processor
*********** board will support a max of 1GB of RAM. Your processor is an Intel at 1.8 GHz. The preceding is only true if your PC is the Emachines T1840 as you chose in the category listing of your post. Again if that is true, you can achieve the max RAM by installing a 512MB stick in each of the two memory slots.
Good luck.
PS: Gdlkn84as528 is correct in assuming that a less than 1.3GHz Intel processor would be a P3 or equivalent processor. So which is it, it can't be both ways?
Sep 18, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
WHAT KIND OF PROCESSOR COMPATIBLE TO FOXCONN P4M800MO1
you can enter in your Mb any type of intel processors ranging max speed bus 800 mhz , for example you can enter intel pentium 4 hyperthreading 3.00 ghz , 800 mhz front side bus 1 mb cache, number 530, 530 j or better than him.
Apr 08, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Can i upgrade this with 1gb ram?
Hi again!
Yepp, you can upgrade it to 1GB memory
This is the spec of the memory on your 2055:
Memory RAM Technology DDR2 SDRAM Max Supported RAM 1 GB RAM Speed 533 MHz Installed Cache Memory 1024 KB
Good luck
Nic
DONT forget tp RATE me
Apr 07, 2009 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
How do I overclock a Celeron 733mHz PGA370?
You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
Max. video card or controler
Get the AGP card with the most memory you can get.AGP is a pretty old architecture. You may need to hunt one up on ebay. Might try Newegg.com
Nov 21, 2008 | ASUS P4B533 Motherboard
Compatible board for P-4
ok so its a 478 socket
best board available is an asrock P4I65g
Specification Value Product Description ASRock P4I65G - motherboard - micro ATX - i865G Product Type Motherboard Form Factor Micro ATX Dimensions (WxDxH) 24.4 cm x 19.8 cm Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz Processor 0 ( 1 ) - Socket 478 Compatible Processors Pentium 4, Celeron D RAM 0 MB (installed) / 2 GB (max) Supported RAM Technology DDR SDRAM Storage Controller ATA-100, Serial ATA-150 USB Ports Configuration 4 x USB Storage Ports Configuration 2 x ATA, 2 x SATA Graphics Controller Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0 Audio Output Sound card - 5.1 channel surround Networking Network adapter - Realtek RTL8101L - Ethernet, Fast EthernetView extended Specifications
Oct 18, 2008 | Intel D865GBF Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Computers & Internet Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
