Question about Malber TD700 Electric Dryer
DRYER SPINS BUT THERE'S NO HOT AIR - Malber TD700 Electric Dryer
    President:
  • 2,187 Answers
Check if the relay or the heating element are still working.
Posted on Dec 12, 2009
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
I have a kenmore stackabler W&dryer model#417.94802301.The dryer spins,and the close are hot,but Theres no air coming out the blower.Can you help with info?And is the dryer motor the same as the...
The dryer motor that spins the drum is the same that drives the blower so being that it spins we know the motor is good.The only thing it can be is a blower wheel issue. I have seen these where the wheel was cracked where it fits onto the motor shaft (they are plastic )and I suspect thats whats happening here the part is about $25.00 and is not that hard to replace but please make sure you UNPLUG THE DRYER pefore doing any repair Good Luck
Sep 17, 2010 | Kenmore Washing Machines
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Dryer spins and gets hot but clothes do not dry
Sound like the air is trapped in the dryer. Is your lint trap empty? Is the dryer properly exhausted and the ductwork clear of lint or obstruction?
Oct 08, 2009 | Whirlpool Inglis IP8200 Dryer
Hotpoint dryer wont get hot
This condition is normally cause by a faulty thermostat...
Sep 22, 2009 | Hotpoint NWXR473EV Dryer
Dryer spins, air flows through vent but isn't hot
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Sep 15, 2009 | Whirlpool LER7646E Dryer
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Air does not go through to clothing chamber'
This is a gas dryer with a glow bar ignitor pat number 279311. It probably has a bad glow bar
Mar 30, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer spins but no hot air comes out
check the fuses.one runs and other heats it.might be a wire burnt off in the back or on the motor
Mar 17, 2008 | Dryers
Kenmore dryer 110.66812690
kenmore dryer 110.66812690 won't get hot blowing out cold air.
Jan 01, 2008 | Dryers
Malber TD700 Electric Dryer Logo
69 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
ray gallant
Are you a Malber Dryer Expert? Answer questions, earn points and help others
