Question about Mitsubishi WD-52628 52" Projection HDTV
No video but have sound everything works except picture lamp has been replaced
  • Mitsubishi Master
  • 5,138 Answers
Ballast Board or you have a defective Fan, if Fan stops running set will shut off.
Posted on Dec 12, 2009
No picture on tv
Can you please provide us the brand and model for this unit so we can help you better...
Oct 25, 2008 | Televison & Video
LG 42LG30-UD No Picture, backlights work, sound works, control keys work. Everything work, but no video. What could it be?
If you can hear the audio, there should be video too; because, without video, the audio will be muted. I assume something wrong with the LVDS cable. Check it. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 03, 2016 | LG Televison & Video
I have a 42 inch Panasonic viera comes on sound is there everything works except picture. Sometimes I have lines of color flash on the screen what's going on.
Replace the video cable and make sure your video input is matched properly with the audio (audio on input 1/video on input 1) or whatever input you are using.
Feb 25, 2015 | Panasonic Televison & Video
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
My laptop screen is bright. Brightness control works but no picture. The picture is ok on external monitor. Sometimes a faint and incomplete picture appears on startup but disappears after a few seconds....
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Aug 25, 2010 | Compaq Presario 700 470024-192 Notebook
XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
Dec 30, 2008 | XO Vision XOD1735 Car DVD Player
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Scanner
SIR, YOU HAVE MENTIONED THAT SCANNER LAMP IS NOT GLOWING AND THE SCANNER IS WORKING PROPERLY;THE STEP THAT YOU HAVE TO TAKE ARE: 1.OPEN THE SCANNER AND SEE IF THE CARD IN SCANNING UNIT IS ALL RIGHT NOTHING IS BURNT. 2.IF EVERYTHING FINE IN THE LOGIC CARD OF SCANNING UNIT YOU CAN HAVE TO REPLACE  THE LAMP .
Aug 29, 2008 | HP ScanJet 2300C Flatbed Scanner
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
172 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
