Question about Whirlpool Washing Machines
Uncertain what model number is cannot find it on washing machine
  • 126 Answers
LIFT THE LID AND LOOK AT THE SPOT WHERE THE LID AND THE TOP HINGE.TAG MAY BE COVERED WITH SOAP.HOPE THIS HELPS .PLEASE RATE MY RESPONSE :)
Posted on Dec 12, 2009
Washing machine wont turn on
see this instructions and fix it. God bless you
User Control and Display Board
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Enter your model number to see parts for your washing machine.
Help me find my model number
Timer
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse
If the washer won't start the line fuse might have blown.
Thermal Fuse
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Jul 21, 2013 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Front Loading Washer
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Dec 10, 2009 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer mav7600aww doesnt get power
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you938a0a02-c262-417d-a982-3a081cef735f.jpg2b39c595-65d9-457a-8ed4-d3bb6d2facd8.giff6783cbc-852f-47b4-98d7-bd94a664080e.gif
May 23, 2013 | Washing Machines
Simpson swt802sa
he most common parts or causes, ordered by the likelihood of fixing the symptom.
Timer
Line Fuse
Thermal Fuse
Main Control Board
Power Cord
God bless you11c63312-8cb1-4484-928d-4b5c239b0f35.gif243403b0-440d-4f8b-b217-fdfd20c409ef.jpegc0210118-4dbd-4ea4-980b-16577c9769fb.gif
Which AC adapter do I use with my New Balance 9.0e Elliptical machine?
see the plate label indicating the serial number, model, and indicating the electrical specification. And proceed according.
Otherwise you must call to the company for customer service and get help online via chat.
God bless you
Jun 19, 2012 | New Balance Exercise & Fitness
User guide for whirlpool fl5064
To obtain the right instruction manual, you need the proper model number. Most "model numbers" on the front of a washing machine are not the proper washing machine model numbers. They are sometimes just the name of a range of machines - each with their own user manual.
Or, contact Customer Support at 1-866-698-2538.
Good luck.
Apr 03, 2011 | Whirlpool Washing Machines
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
Washing Machine
The model number will be located under the lid along the wash tub opening. Post back with your COMPLETE model number and I can see if I can locate a manual for you.
Jul 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
