Question about Hotpoint Refrigerators
Clicking sound coming from the main control board, constant click sometimes for several hours, the compressor is trying to come on but with each click from the control board it does not engage. Somtimes it engages and the refrigerator will run fine for a few hours, then back to the clicking sound again for another 10 to 12 hours. Then sometimes it just won't work at all no sounds nothing and everything in the freezer melts., then another day it's working fine, then the next day the clicking again starts at the control board in the back. When I depress the ice, water dipenser the clicking stops, when I let go the clicking starts back up after 5 seconds.
  • Hotpoint Master
  • 3,361 Answers
There is a stuck relay on the control board.
The control board will have to be replaced.
Posted on Dec 12, 2009
My refrigerator is doing many clicks and compressor is not starting. Sometimes for 2 hours before the compressor finally start. Do you know what could be the problem? Model GBS22HBSWW
the clicking is the main prosser board .in the back . it controls the defrost and run of compressor . it needs to be replaced . hope this helps **** .
Jun 15, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Clicking sound
That is your compressor overload switch, and it's telling you that your compressor is overheated. Sometimes this situation will clear itself up by turning off your fridge for a few hours until the compressor is cool to the touch. This clicking problem can be caused by several things including a worn out compressor, but is often caused by turning the thermostat up and down several times in succession which overloads the compressor.Try letting it cool to the touch and restarting before trying a repair. that may be all you need to do.
Mar 13, 2010 | Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
I have a GE referigerator Model # GSH25KGRE of 4 years old... I hear a constant click-click noise coming from the back/motor..and I suspect the temp in the freezer is slowly dying down..
The clicking behind the refrig , is comming from the main control board , behind the 8" X 10 " panel . The part number is WR55X10656 . The compressor relay , on the board has burnt . Yes , your freezer is thawing , due to the clicking .
Sep 23, 2009 | GE Refrigerators
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
Fridge prolems Electrolux ERE 3500
Disconnect the power cord (or switched power off) and wait an hour or two until compressor has cooled. When you now switch the power on, the clicking is heard only once and compressor starts (weak noice and vibration noticed). When compressor gets warmed, the compressor will stop and clicking starts again (clicking comes from electric circuits when compressor is switched off and on repeatedly, but it will not start because it has stucked - this is typical fault in old compressors said maintenance expert to me). Buy a new fridge.
Mar 29, 2008 | Refrigerators
Constant clicking from freezer fan that won't start
Could be the defrost cycle is not running properly and the fan has ice on it.
Oct 28, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH25JSRFSS REfrigerator not working
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Sep 03, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Open Questions:
Refrigerators Logo
344 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
