Question about Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
I bought and fitted a Hitachi 500GB SATA Hard Drive to my Dell Dimension 5000 Desk Top, but the desk top don't seem to pick up the SATA. I mate of mine said I need to get drivers for the new Hard Drive - I've looked around on the web, but can't realy find anything. Can anybody offer any help please.
Cheers
Hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
Posted on Jan 23, 2008
You need to turn it on in the Bios so the computer sees the drive, then format it.
Posted on Jan 22, 2008
I cloned a 300GB XP boot drive on a 4GB Dell GX280 to a 500GB HD on a 1GB Dell Dimension 5000, but even in Safe Mode, when I try to start up from the 500GB, I get the 0x7b BSOD...
the 7b is a hard drive controller issue the controller on one computer is not the same as the other. maybe try the ultimate boot cd to clear the problem
Nov 26, 2015 | Dell GX280 Optiplex 2.8GHz Desktop...
How i can install the new HITACHI HDS721010CLA har drive in to my dimension E510
Hi castanedajes !
Here is a link to the Hard Drive section of the user manual of the Dell Dimension E510. It detailes all of the procedure.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Best of luck omerk.
Jan 28, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Need to add extra bays
Have you used any spare 5.25 in bays yet?.....the wider ones at the top when the optical drives live? .... you can get 5.25 to 3.5 in side rails to fit to hard drives so they fit in them.
Dec 31, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Dell Dimension 5000
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
May 04, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 5000 Desktop
You don't need drivers for a hard drive! Just plug it in and it will be recognised by the BIOS.
The only thing you will need to do is make sure you designate it as a primary or slave drive - whatever the old drive was set to. On the back there is what looks like an eight pin plug, with a jumper across two of the pins. Depending which pins are connected will change the drive designation. There is usually a sticker next to them telling you which to connect for primary and slave.
Matt
Mar 21, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Hitachi ( 0A30229-20pk) 400 GB Hard Drive Logo
3,062 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
