Question about ASUS Computers & Internet
My cpu is running but i don't hear any sound beeping.
    President:
  • 2,923 Answers
Try to remove the RAM and video card, clean the gold plated pins with dry cloth and re-seat them. Then turn the computer on.
If you get the same problem, most likely, you've got a bad RAM or video card.
Thank you!
Posted on Dec 12, 2009
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
I have a question regarding my cpu dell inspiron..Heres my problem: 1. when i start my pc sometime the fan is spinning then suddenly its stop adn run again and then I dont hear any beeps form the board. I...
There is a circuit on the motherboard that detects the ambient temperature of your computer. Your CPU fan has 2 speeds - if it detects the temperature inside your desktop getting hot, it will switch the CPU fan to hi-speed. If you removed the memory and powered on the computer and don't hear any Beep codes then you probably have a problem with the the motherboard and it needs to be replaced. disconnect cables to CD/DVDdrives. Look at the USB ports to see if any are damaged.
Aug 14, 2011 | Dell Inspiron 530s Desktop Computer
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
How will you know if the processor is still working?
Finding Out the CPU condition whether its working or not
  • 1
    Turn on your PC and listen for a beep. Your computer runs a diagnostic upon startup called "post." Post checks for the basic requirements for your system. This includes RAM, processor and video functions. If those three basic elements are working properly, you will hear one beep from your computer's speaker and you can be assured your processor still works.
  • 2
    If you hear multiple beeps, count the number of beeps you hear as this will help you determine if your processor is functioning properly. If you are running Phoenix BIOS, make sure you count and write down the beep sequence.
  • 3
    Consult your motherboard's BIOS instruction manual; there will be a section on the "post" startup. Five beeps means a processor error for most standard AMI BIOS systems. The number of beeps you here will tell you the problem your computer is experiencing that is preventing it from booting up. Once you know how many beeps to look for, you can safely determine if your CPU is still functioning properly.
  • Jan 19, 2011 | Intel Pentium 4 2.40GHz 512/400/1.5V...
    Loud beeping sound on start up , now will not start up , power ok
    First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
    Jun 03, 2010 | Asrock K7S41GX Motherboard
    I hear beeping tone in my cpu when i plug it
    When the computer makes those funny sound via the system speaker, it's not doing it because it wants to be heard. The computer is trying to talk to the operator/technician and tell them what's wrong.
    So here are some codes to give you an idea of what might be wrong with your PC.
    Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
    Nov 30, 2009 | Computers & Internet
    MSI P6NGM won't BOOT
    You should only hear 1 beep. That 1 beep is power on self test, known as P.O.S.T.
    That loud flat line sound (And I'm pretty sure about this), was you're CPU. Just because you ran & passed the stressed test is nothing compared to running the system under load? That's why when you put in you other memory nothing changed. If you hadn’t mentioned you clocked up the FSB I would have come to the same conclusion hearing the loud flat line statement.
    Can you test the CPU in another board? That is about the only way to be sure it's not the CPU. Memory does not make that kind of sound. Memory makes short & long beeps.
    You can try clearing the cmos/bios by going to pg. 2-18 in you're user manual. This will reset the bios back to default settings & cross you're fingers!
    If I can be of more service, just post back & let me know how thing go.
    Good Luck!
    Mike
    Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
    PCVRS620G won't turn on
    i feel this is not a big problem. if u hear a beep of ram on beap on boot then ram is ok just short it and check for displaay. check ur cpu socket it may be loose. if u don hear a beep on boot change the ram and ur problem will be solved
    Feb 07, 2008 | Sony PCV-RS620G PC Desktop
    New Acer Aspire E700 does not load-up
    Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
    Jan 01, 2008 | Computers & Internet
    Computers & Internet Logo
    24 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
