Question about Toshiba 57H82 57" Rear Projection Television
The picture is scrambled. you can see the red, blue, and green colors separately. After a couple minutes of this scrambled screen it turns off and the standby light begins to flash.
  • Toshiba Master
  • 8,457 Answers
Ur convergence it dead.Know how to solders?Tries these websites for convergence kit.Tv repair World.com,Tv repair kits.com
Posted on Dec 12, 2009
2 Suggested Answers
  • 8457 Answers
SOURCE: picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair World.com,Tv Repair Kits.
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Re: Toshiba 65 in Cinema Series - 12 years old. Color Separation. Green bow at top center of screen, red and blue double images tilting upwards toward sides. Sometimes clears unassisted after set has...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 20, 2011 | Toshiba 65H82 65" Rear Projection...
Picture colors scrambled
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
After a few minutes the color goes to intense red and green
My tv didn't turn green, but the red separated significantly. It started off happening after a few minutes of being on (I suppose the defective part was "warming up"), then it got to where it was like that immediately upon turning the tv on. In my case, I had to pay a tv repair man $350 for a new part. There are 2 microcircuits that control the color alignment--one that controls the red only, and the other controlls the other 2 colors, blue and green I believe. Maybe your part is the blue/green controller, mine was red. The repair man said these parts fail so rarely they don't stock the part. The cost of repair may be different for a different part, but either way you have to choose if it's worth that cost to you. If you get rid of it, I'll buy your tv stand ;-), I bought mine from a friend and didn't get the stand in the deal.
Dec 14, 2008 | Mitsubishi WT-42315 42" TV
Red Blue and Green?
All colors in a tv are made up of red ,blue and green,,. my projection in the menu has under setup,,just check for it,,its called conversion ,it realines the colors,, you have to do it periodicaly,or sooner if you move a projection tv,, thanks,, .it should have it,,good luck
Oct 05, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Problem with color
Yes you have a problem in the red crt driver board. Most likely the driver transistor is failing. This is a component level repair, so if you have no experience with TV repair, play it safe and call in a trained tech to assist you in this matter. Good Luck
Jun 05, 2007 | Mitsubishi VS-50609 50" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
174 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
