I need an M70 amp power transformer, 1 channel doesnt work, a stereo repair shop diagnosed it to that.
  • Audio Player... Master
  • 5,390 Answers
I have my doubts about the transformer. Most power transformer faults would take out all channels, not just one. I think it highly unlikely that both channels have two seperate transformers to supply them with power. It's more likely that the fault is caused by whatever is mounted to the heat sink. It's likely they saw you coming mate!
Posted on Dec 13, 2009
Sony av receiver #str-dh700. only could hear relay clicking when i press power . the system could not be come on . what it be / & how to repair it?
One of two things. Either the main power fuse is open or the power transformer is bad. If the fuse is blown, then it usually means you have a bad amp channel that needs to be repaired. If it's not the main fuse, then the thermal fuse in the transformer may have opened which requires the transformer to be replaced.
Jul 03, 2013 | Audio Players & Recorders
Need a power transformer from 220input to 120output
What you need is simply a power converter device that knocks the power down for your device. Look for a UK (European) to USA power convertor on somewhere like Amazon.
May 04, 2013 | Bose Lifestyle SA-3 2-Channel Amplifier
My AKG C1000S shows a weak signal from one side of the two stereo channels when I use an XLR going to a 1/4 inch Stereo jack. Does the mic only work properly with a Mono jack?
You have connected the mic improperly. You'll need an XLR to 1/4" transformer to properly match the impedance, then run into a mono channel.
Mar 15, 2012 | AKG C1000S Professional Microphone
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
Mar 23, 2011 | Behringer EUROPOWER EPX3000 Stereo Power...
I just got one what is it an how does it work an how do i hook it up?
2 channel power amp
you will need additional equipment for this beast to work right.
1. you need a pre-amp, all audio connections go into the preamp which control sorces, volm, bass and treble.
2. out from the preamp into the power amp and out to your speakers
3. you can freak it if you have an 1/8" stereo to RCA stereo plug in this caee you can play your ipod, phone or mp3 player thru this amp using your input device (ipod, phone or mp3 player ) like a preamp to control volm, bass and treble.
Feb 21, 2011 | Sharp SX9860 2-Channel Amplifier
Yamaha m70 amp and c70 pre-amp right speaker stopped working
First, lets's determine if it's the amp or the preamp...
Swap the Left and Right channel cables between preamp and the amp with each other.
Did it stay on the right? = amp problem.
Now on the left? Preamp or source.
Plug any Line Level device (CD?) directly into the amp inputs. Work now? Preamp problem.
ALL sources? Preamp - toggle all controls, especially a Tape Monitor to possibly wipe of any built-up oxides in them.
May 31, 2010 | Audio Players & Recorders
Crown CE1000 amps, 1 dead channel - Can I diagnose via RJ-45?
Before asuming it is the power transistors check the power on relay first as mine had the same proble and it was because of the Relay that did not switch on the one channel or amp (remember this is a power amp and consist of two mono amps)
Nov 07, 2009 | Crown CE1000 2-Channel Amplifier
QSC ISA 280 Stereo Power Amp stopped working
This is a very precise questions as QSC amp are pretty rare and high end electronics equipment. There is no way getting an answer other than getting the amp at a sound shop for repair, wich might go for a visit at QSC anyway. From a sound shop repairman...
Sep 07, 2009 | QSC ISA 300Ti Amplifier
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Distorted sound
This is an automatic high end amp. Make sure you are using 8 ohm speakers. If the connections are correct, also use good quality speaker wire.
If this makes no difference, it seems that it would need to go to the repair shop.
Feb 18, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
83 people viewed this question
 Grubhead
Grubhead
