Question about Cuisinart PSC-650 6.5-Quart Slow Cooker
Is there a way to repair the retractable cord re tractor? I pulled the cord out too far and now it won't retract.
    Problem Solver:
  • 5 Answers
You must disemble ,wind the retractor all the way up then allow to **** the cord in you may have to disconect the cord the recon the cord
Posted on Dec 12, 2009
I want to order an elite pressure cooker cord mine got lost
Gwen, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Your AC Power Cord Connection Electric Cord Sets
http://www.powerpressurecooker.com/parts-and-accessories.php
Appliance Cords
CORDS small appliance cord sets electrical cords vacuum cords
Mar 03, 2016 | Crock Pots & Slow Cookers
Where can I get a replacement insert and lid?
It is possible a local appliance parts supplier might have what you need (or equivalent parts that will work).
Jan 14, 2016 | GE Digital 6 Qt Slow Cooker Dishwasher...
I need a new electrical cord for my crock pot.
These should be available from any electrical shop. Very often even kettle cords will fit crockpots. Take the old cord with you when you shop.
Nov 21, 2015 | Crock Pots & Slow Cookers
My WP pressure cooker won't turn on, at 1st you could jiggle the cord and it would turn on but now that does not work either. Is it a bad cord or he prongs it connects into?
Without the device in front of me i can't say which part is the problem. I would suggest first checking the continuity of the cord with a voltmeter to see if that's the problem. if so, replace the cable. If it's the internal part of the pressure cooker, take it into the shop for repairs.
Jun 18, 2015 | Crock Pots & Slow Cookers
Rice cooker retractable cord burned.
If the mechanical part is still good then any handy person can replace the cord with any purchased cord but to do so safely it would be best to have someone with electrical training to do so
Nov 24, 2013 | Cuisinart PSC-650 6.5-Quart Slow Cooker
The lights are flashing and won't stop. I tried to unplug and replug same results ...what should I do?
As far as I know, the flashing lights are an indicator that the slow cooker is on, but awaiting instructions. You need to put in a time and then a temperature and then it will stop.
I personally find the power button very disconcerting and keep having to stop myself pressing it once I've programmed the slow cooker, and accidentally switching the thing off.
Nov 05, 2012 | Rival 38601 Smart Pot 6-Quart
Cracks in slow cookers. what causes that and how can it be fixed?
Cracks caused normally in slow cookers is normally caused from the unit being real hot, and then put under facet cold water. When the unit is very hot, and then is put under cold water before it has cooled down on its on to a warm temperature the dramatic change of hot to cold, cracks it. When its hot, its expanded, and then when it goes that fast to cold, it retracts to fast and causing cracks over a period of time, like stress cracks on air planes, when they go up they expand with cabin pressure, and when they come down to land they retract, over a period of time they get worn and cracks develop , same as a crock pot, except yours is with heat, the planes are with air pressure.You can't really fix the cracks. Well, you could have a shop fix them. but the cost would be way more than the crock pot. The only way you can help this from happening in the future, is after using it,before you wash it out let the crock pot cool down on its own for a while. Thanks Mike
Sep 14, 2011 | Crock Pots & Slow Cookers
I need a replacement cord set SH-1. Is it available anywhere?
What is the spacing on your cord attachment pins on the base of the crockpot 1/2" or 1 1/16" ?
The 1 and 1/16" can be found here:
(6 ft cord)
http://www.nelsonappliance.com/shop/products/roaster-oven-appliance-cord-6.asp
The 1/2" X 2.5 ft cord can be found here:
http://www.nelsonappliance.com/shop/products/percolator-appliance-cord-2-5.asp
Thanks for choosing FixYa
Kelly
Aug 28, 2010 | Rival 3355 5-Quart
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
My crockpot's cable was damaged from heat.
amy i would try to tell you how to fix this but i would cost you some money to buy all the things to fix it you might try to go to a tv repair shop and see if they could put another cord on it for you they might charge you 5-10 dollars for this k
Nov 03, 2007 | Rival 37601 6-Quart
Cuisinart PSC-650 6.5-Quart Slow Cooker Logo
459 people viewed this question
Top Cuisinart Crock Pots & Slow Cookers Experts
dannydoesita
Tom Chichester
DocZachary
DocZachary
Are you a Cuisinart Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
