Question about Hotpoint RGB745 Gas Kitchen Range
How do u relight a pilot on a hotpoint model #RGB745WEH77WW
    Problem Solver:
  • 5 Answers
Normally the pilot flame is in the back of the oven use long match watch for gass explosion may be small but be careful should be in the back middle of the oven.
Posted on Dec 12, 2009
2her is pilot light on remeha avantaplus boiler
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
Jan 13, 2016 | Water Heaters
Converted HotPoint RGA720 to LP, burners and oven work fine, all pilots flames are still too high?
I have this model too and have had to replace two thermocouples because the pilot is so high it frys them. We replaced the whole modulator last time and it still goes out so I have to relight The pilot is at the lowest setting, it's a GE/Hotpoint issue that was not recalled. I do like the hot 125 degree oven for drying sun dried tomatoes and keeping plates warm.
Apr 13, 2013 | General Electric Hotpoint® RGA720PKWH Gas...
Maytag gas dryer not heating
First make sure you have gas, then open lower section of this dryer you shoul see screws you will see a place to relight the pilot , if you smell gas before doing anything then stop your repair, see if the pilot is lit then push the red button and hold it relight pilot hold this button for a few min's after it relights, if it dosent relight check power goign to gas valve near pilot . Gas units have very little problems you may have just lost gas pressure and need to relight it , let me no ! what you see and we wuill go from there
Jul 27, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Have a Model #21V40-7 Natural Gas Rheem water heater and the pilot has apparently gone out. Can you tell me how to restart the pilot and what position the controls should be in for this model and...
The main control knob will have a "Pilot" position. Set it there, then light the pilot. You may have to press and hold the control knob to do that. There may be a striker button that will relight the pilot while you're holding the control knob or you may need to use a match or a candle lighter.
Once the pilot is on for 30 seconds or so, it will remain lit when you release pressure on the control knob.
Dec 27, 2017 | Kitchen Ranges
I have atwood pilot relight model gc6aa-8 pilot will light but after tank heats up & there is no call for hot water,pilot is out and very hard sometimes impossible to relight.
So are you saying that the first initial lighting of the pilot, without turning to on, works o.k., good flame etc, ? If not sure, try lighting pilot only, and leave setting at pilot only, and see if it's a good flame, and get back to me.
May 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Pilot light is out need to relight it but do not know where it is located
The pilot is located in the bottom of the stove, you will have to remove the bottom drawer, and you will see the pilot in the back, you can relight it there, if there is no bottom drawer you will have to remove the bottom cover inside the oven and this is the location where you can relight the pilot.
Jan 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
Lochinvar water heater model LTN040G. Can't move dial from "on" past "pilot" to "off" to relight. Seems like there must be something I need to do to make it move, but can't figure it out.
The valve should be able to be depressed at the pilot setting and as you slowly depress it you should get it to move past pilot to off. You do not however need to go to off. You can go back to pilot and relight it and go back to on.
If it will not relight and will not go back to off it sounds like the valve is damaged internally and will need to be replaced.
Aug 07, 2009 | Pool & Spa
Why frequently relight my pilot?
check for water run off from above or sprinklers directed at heater. A high wind stack may be needed due to heater location. Millivolt models have a thermocouple or pilot generator that may be faulty or weak. Loose or rusty connections of the thermocouple to the gas valve or loose coil connection, or short in these wires can shut off a pilot.
Aug 27, 2008 | Raypak REFRACTORY KIT
Hotpoint RGB745 Gas Kitchen Range Logo
278 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
