Question about Estate TGDS840JQ Gas Dryer
I have an Estate dryer model # TEDS840PQ1.. when I press the start button nothing happens.. I can hear the timer count down and the light comes on when the door is opened.. when I push the door switch the light goes out as designed
  • grshoppa Dec 12, 2009
    Unfortunately my meter is in my toolbox at work and I can't get it till monday.. can I jump two of the wires to see if it is the switch ?.. The switch has three wires.
  • 6,784 Answers
HI. The start switch may be the culprit here. I recommend testing this switch to confirm the damage.
Locate the start switch(Usually located in the control panel housing). it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
For a three wire switch, touch one probe to the terminal labeled NC (or CT1) and touch the other probe to the terminal labeled CO (or R1). You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
If the switch fails either test, it should be replaced.
NOTE_ IF the start switch passes the test, the timer will be the culprit, due to damaged circuitry.(This is uncommon, but likely).
Posted on Dec 12, 2009
  • Michael Masters
    Michael Masters Dec 12, 2009
    Yes, you can jump the switch.
Our whirlpools dryer is heating but when i push the start button nothing happens. the light comes on when opening the door and timer counts down.
The drive belt has broken. Copy the model and serial numbers and go to an appliance parts store for a replacement. You will have to pop the top off by inserting a putty knife in the front corners to release the clips, and depending on how you dryer was built, remove the front or the back panel. Slip the new belt over the drum, move the belt tensioner to the side, then loop the end over the motor pulley.
Sep 11, 2011 | Dryers
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
I have a whirlpool gold ultimate care II heavy duty gas dryer. When the dial is set on any setting you can hear the motor ticking. When I push the start button I get nothing. Any ideas???
You are probably hearing the timer count down, which means the timer is working right. This sounds more like your start switch is out. If you email or callus with your model number, we'll be sure to get the right parts out to you rigth away so you can get this repaired. We look forward to hearing back from you soon. Hope this answers your question.
Sep 28, 2009 | Whirlpool Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer wont start
I would check the door swith first.
Jul 15, 2008 | Estate TEDX640JQ Electric Dryer
Kenmore electric dryer won't start
The first thing I would check would be the door switch. Dryers operate on 220 volts. Many brands split the 220v into 110v for controls and motor and 110v to the heater. There are also safety systems on many brands that won't allow the heater to come on if the fan motor is not running and blowing air throught he element to prevent overheating and dryer fires. If the door switch is ok, check the belt. If the belt is ok, it could be a problem with the motor start switch. The motor start swith is complicated fix and should be done by a professional. ALWAYS BE SURE TO DICONNECT THE POWER BEFORE ATTEMPTING ANY REPAIRS.
Mar 24, 2008 | Estate TEDX640JQ Electric Dryer
Estate TGDS840JQ Gas Dryer Logo
53 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
