Question about Hunter 30124 Air Conditioner
How do I change batteries in a Hunter airconditioner thermostat
How do I open the thermostat to change batteries on a Hunter thermostat
    Problem Solver:
  • 15 Answers
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Posted on Dec 12, 2009
Why won't thermostat turn on after I changed the batteries?
I think you may have the model # incorrect, However if you have a thermostat as in the type that are hand held, polarity of the batteries is the 1st thing I would check, then test them for proper voltage, corrosion will often interrupt that small of a voltage, clean the terminals and test it .
A wall mounted like a central HVAC system typically will not require batteries to operate, this is for memory and they will work fine even if no batteries are installed, however there are battery powered stats too, meaning non parasitic type that not powered by the transformer in the air handler.
I will include a basic drawing of a residential HVAC thermostat to show you how the 24 volts powers most thermostats.
ome > Air Filtration > Air Cleaners and Purifiers > Hunter Air Purifiers > Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer Hunter 30124 HEPAtech 124 Air Purifier w/ Ionizer
Item #: hun30124 892f1d0d-b50f-49aa-8079-70d2dc34eb2b.png
Jun 07, 2014 | Hunter 30124 Air Conditioner
I HAVE CHANGED MY BATTERIES ON MY HUNTER THERMOSTAT AND RESTET IT BUT IT STILL GOES BACK TO DFAULT AND AND E STILL REAPPEARS AND MY AIR WILL NOT KICK ON
http://hunter-thermostats.com/hunter_manuals.html - This site has the owners manuals for a list of Hunter thermostats. You will need your Model Number.
Apr 03, 2011 | Heating & Cooling
I have an Hunter Indiglo 44250 thermostat. I changed the batteries and now have nothing on the screen at all. I tried resetting it already and nothing is happening. Thanks!
Having a problem with my fan staying on continuously even after my furnace has finished heating. Cool air blows throughout the house all day and night.
Aug 09, 2010 | Hunter Fan Company 5/1/1 Programmable...
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
How do you open the theromsatat to change batteries
Usually the face of the thermostat pops open with a little force.
Apr 05, 2009 | Hunter Fan Company 5/1/1 Programmable...
Low battery on hunter 44422
I have the same unit, 44422. The base has four clips, two on the top and two on the bottom. The front portion is clip-on. Try to push on the base's bottom and pull off the front portion, like opening a book. After the battery replacement you will have to reset the unit trough the little reset hole. Otherwise, the ''LOW BATTERY" will not go away. Yes, you will have to reprogram the unit.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Jul 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 30124 Air Conditioner Logo
205 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
