Question about Frigidaire FMV145K Microwave Oven
Microwave oven light under microwave won't turn off and the unit won't turn on
    Novelist:
    Scholar:
  • 96 Answers
Hi\
Well it moslikly the problem is a bad switch , there located insde the unit, it's posible the plastic made like lever that turns the switches on or off is jamed or broken.
To check them unplug the unit , open the cover, with an ohm meter check to see if they turn on or off. Basic electrician rull, most of them don't know this.
If all seem to be ok, double check, It's mostlikly 99% your problem , the other percentage is a bad board cause by a bad keypad or board, witch it's very small.
Regards
Bob
ps if it's the keypad or board like all other 99% of population tuss it out, keep in mind don't complain there to mutch air polution your also a cause of the problem.
Posted on Jan 20, 2008
Micro won't work after boiling water under it all day
I am not sure what you mean by boiling water under it all day. If it was under the unit, it probably shorted it out and it won't work. If you were using it constantly to boil water, you may have overheated it. To be safe, please unplug it and call the manufacturer.
Feb 14, 2013 | Samsung SMH7178STD Microwave Oven
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
Microwave just won't stop
One of the door switches is defective, sometimes caused by food particals this is a safety issue and should be corrected.
Mar 08, 2012 | GE JE1540 Microwave Oven
Carousel quit turning and light won't come on.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;;'
Jun 28, 2011 | Magic Chef MCO160UQ Microwave Oven
Under microwave light stays on
LET ME GUESS , this is a GE SPACEMAKER , OR A KENMORE ? this is a super common problem with this microwave . your control board is bad , you can get one at searsparts.com . but i warn you the cost is REAL HIGH and if your microwave is over a few years i would not fix it if i where you . this oven had another FUN thing it does . it turns it self on for no reason and have been known for burning down houses .
Mar 17, 2009 | Sharp Microwave Ovens
Does not heat
The magnatron unit has malfunctioned. You should be able to replace that unit if you're mechanically apt, although with the price of microwave ovens, you might just as well get a new one that's under warantee.
Apr 21, 2008 | Sharp R-1490 Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
57 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
