Question about Belkin Computers & Internet
I was not able to get on the internet so i had to dc it ad directly conect to the modem is possible the router has gone bad
    Guru:
  • 1,738 Answers
If you are not network orientated it will be complicated. The simple way to do it is to plug the ethernet cable into the lan port of the router, and it will worked. Your will not have a hardware firewall protection.
Another way is to have the router it's own router and the modm it's own as well. My modem is 192.168.1.1 and my router is 192.168.9.1 those are the lan network address.
Posted on Dec 12, 2009
SOURCE:
I have a new belkin n150 when i conect to the modem, there is a amber flash light for the modem on the router, when i conect the computer directly i have conection, i have folowed all the instructions but...
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
Feb 21, 2011 | Belkin N150 Enhanced Wireless Router...
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
How to conect internet to pc & laptop
the easy way would be to get a router and plug your internet device(cable modem,dsl modem etc.)into the router and then you computer and laptop,most newer routers are wired and wireless so if your laptop has wireless in it then you dont need to use another cable.Also i would recommend the netgear wgr614v10 router its a very good router and easy to set up,comes with color codes and directions.It can be purchased at any walmart,bestbuy,compusa,or most other electronics stores,and the price isnt bad either,here where i live it cost me around 40.00,some places are cheeper.
Oct 29, 2010 | Computers & Internet
When i connect my router to my modem i get limited connection could my router be gone out i have to connect direct to lap to get internet service
If Windows is saying "limited conectivity" on the network Icon in your takbar then it seems, the DHCP server function on your router is disabled. If that is the case, then I would perform a factory reset on your router then reconfigure it. If that is not the case, some ISPs require that your PCs mac address match your routers mac address. There should be an option in your routers configuration page to "Clone Your Mac address" or something similar depending on what model of router you have. If all else fails, fully reboot your modem, then your router, then your PC, in that order.
Oct 28, 2010 | Computers & Internet
I can't get the internet sharing to work. i had installed and configure the wireless router, Linksys WRTG45 connected to a desktop pc running win7. internet sharing is enabled on the modem. now we're using...
If you are using the wireless router then you will not use the Ad-hoc mode.
You aloso don't need to share the internet on the modem.
make sure that if you conecnt the computer directly to the modem, it goes on line.
If it is on line then you can connect the modem to the router and computer to the router.
open the setup page and change the settings of the router.
once ytou setup the router then you should be able to go on line on all the computer.
You just need to connect to the network on other computers.
Click Here for more information about the routers and network
Aug 18, 2010 | Computers & Internet
I couldn't connect to the internet until the router was disconnected and the broadband modem conected directly to the computer.
If you connect the modem directly to the computer, it works . that means the internet is working. You will need to check the settings of the router. For this you will need to acces the router set up. Click Here to know more about router set up
Nov 16, 2009 | Computers & Internet
Added Cox Phone Service/Modem and now 2614 router won't work
That would be a problem for the Cox phone service provider.
Jul 06, 2017 | Siemens SpeedStream 2614 Router (ss2614)
I can't access the Internet by Belkin Router f5d7230-4
Make sure your connections are right, 90% of problems result from bad or incorrect connection. If this still doesn't work, try unplugging the modem and router, leave it off for a couple of minutes, then plug everything back in. If this still doesn't work, try your local computer repair shop and see if they can futher assist you. Hope this helps! If you have any questions, send a comment
Jul 12, 2009 | Belkin (F5D7230-4) Router (587009)
Internet Explorer is not conecting
You may have a modem or router problem, not problems in your computer. Try resetting your modem and router (if you have one). Turn off power, wait about a minute, then turn them back on. Sometimes that is all that is needed.
If you have a router connected to the modem, eliminate that by connecting your computer directly to the modem's network jack. If you can connect then, you know you need to replace the router.
Try another computer if you still can't connect when running directly to the modem. (You should be able to find someone with a laptop who can try for you.) Connection failure then can only mean the modem is bad. In many cases a bad modem will be replaced by your service provider.
It is also possible you managed to get a virus or worm into your computer at some point, and that has broken the networking function in Windows. You could try using System Restore to take the computer back to an earlier time when you were able to connect. If the trouble is due to malicious software, though, System Restore may not be available. Some bad software disables that so you can't use it.
Mar 27, 2009 | Microsoft Internet Explorer 6
I have two computers that I want to share my cable internet connection. When connected directly to the modem the first computer conects to teh internet fine. But when I connect the computer to my Belkin...
Perhaps one of your ethernet cables is bad?
When everything is connected, the "WAN" light on your router should go on, as well as the lights for whatever network connections your are using for your computer.
Obviously the cable that you used to connect your computer directly to the modem is working, so try replacing the other one.
Sep 05, 2008 | Belkin Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
