Question about Pinnacle Studio MovieBox DV 9 (210100349) Video Capture
I need power adapter volt/amp - Pinnacle Studio MovieBox DV 9 (210100349) Video Capture
  • 5,603 Answers
Looks like maybe 3.3 volts, 1.5 amps not sure of the polarity.
The Pinnacle Studio MovieBox DV Includes
  • MovieBox DV external analog to DV converter
  • Full version of Pinnacle Studio 9
  • Hollywood FX transitions
  • TitleDeko for titling
  • 4pin/6pin IEEE-1394 FireWire cable
    6pin/6pin IEEE-1394 FireWire cable
  • Power Cord
  • Power supply: 110V 60HZ 3.3V/1.5A
  • Studio Software 9 manual
  • MovieBox DV hardware manual
Posted on Dec 12, 2009
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
Jul 08, 2015 | Cars & Trucks
I need a car power adapter for the product.
Electronic stores, Walmart, & even pharmacies now carry various adapters for products. You may want to check there.
Oct 22, 2014 | Anycom HCC-500 Bluetooth Car-Kit
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
Feb 06, 2013 | Sharper Image Audio Players & Recorders
Ampage for 9-volt alesis sr-16 drum machine adapter
Here is a link to a discussion about this that will help:http://www.soundonsound.com/forum/showflat.php?Cat=&Number=679914&Main=679565 A 9 volt A.C. 3.2 amp power supply should work for you. Just remember A.C. not D.C. is required.
Dec 10, 2010 | Alesis Sr 16 Stereo Drum Machine
How to I install Benwin 3d surround and subwoofer speaker to my PC
You should be able to plug them into your sound card. If an adapter is needed, they can be found at almost any electronics store.
Aug 31, 2010 | Benwin BWS30 Computer Speakers
Power adapter of Avocent SwitchView® 1000
All power adapters usually have a label on the bottom of the adapter that show voltage and current for both the input and output connector, unless that label has been removed. Your KVM switch may have the voltage and current requirements printed on a label on the bottom of the device.
Feb 16, 2010 | Avocent SwitchView 1000 KVM Switch
What is the dc input for JBL Media 100
They run @ 12 volts 850mA. So an adapter with center pin positive at around 1A(1000mA) would give it enough "headroom". This means it would run cooler and last you longer. Amperage consumption is determined by the power it is producing, how loud you are playing the setup.
Mar 13, 2009 | JBL Media 100 Computer Speakers
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
What voltage is the dc adapter?
You will need at least a 4 amp rated regulated 12 Volt power supply.
These are commercialy available from most electronics parts suppliers.
They come on a circuit board. You can mount it in your own case and
use the original Viewsonic wire end. If you do a google search for 12
volt reglated power supplies you should find many of these.
However, with a second-hand Sprint AC adapter with 3A,
12v adapter, the screen blinks on and off
intermittently. Obviously there is some difference here between a class
2 adapter and a power supply box.
Oct 03, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Plugs for Astra Scanner 1220U
Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
Pinnacle Studio MovieBox DV 9 (210100349) Video Capture Logo
590 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
