Question about Kitchen Appliances - Others
Can you help with a old maytag hit and miss engine from the 1930s? I need to know the fuel they burn. I need to know if they use motor oil. I need to know where you add these two,I don't have a manuel.
I found it on the web with just a little time.You guys should really charge on a case by case basis.My qoute from you is ridicilous!
fomoco1
Posted on Dec 12, 2009
  • phillipgolde Jan 17, 2014
    The Maytag is a two cycle engine. Mix two cycle oil with gasoline.
Car cranks but doesnt turn over. radiator keeps needing more water but its not leaking. gas isnt getting to the engine
could be the head gasket has gone take out spark plugs and check there condition and look for water in the piston, water and fuel dont burn well. as you have done an oil change it may have gotten into the oil but its harder to tell with new oil, as water will sit on the top of the oil.
Aug 09, 2017 | 1997 Honda Accord
Mercury outbord motor missing
First, you will get more response in the boat or outboard section of Fixya. You are listed under Cars and Trucks.
It will also help if you state the Year and size of the motor. If I remember correctly, some of the motors had screen filters for the fuel and some had individual feed lines to each cylinder.
Check your fuel lines so you know that you are not drawing air instead of fuel. Also if this is a 4 cycle motor, they had a low oil cutouts and they can work so fast that you would not detect a miss, just a drop of RPM.
Sparkplugs are reasonable, throw in a new set , keep the old ones for emergencies and see if that helps.
Relist in proper section if my solution does not work. Please rate.
Oct 25, 2012 | Cars & Trucks
Dead cylinder....timming is right, getting fuel, spark is fine...compression test shows all cylinders are the same, good...the car only runs on 2 cylinders instead of 3...plugs and wires are new...
cant happen, you missed something, if you have spark, fuel and compression the cylinder will hit, go check again, when doing the compression test kill the spark and lock the throttle wide open. most common thing we see on the 1.0L 3cylinder is burnt valves most common cause is the wrong motor oil the valve lifters can not release the oil back threw the bleader hole if you use to heavey a motor oil, we see owners change the oil and use 10W-30 or 10W-40 and usely within 5000 miles the valves will burn, if you want to use the heaver oil then you need to replace the lifters with an updated part number that has the abilty to use the heaver oil.
Sep 26, 2011 | 1987 Chevrolet Sprint
Hi, I own a 3.0 d4d toyota fortuner (same engine as 3.0 d4d hilux) and as of yesterday it started belching white smoke. it starts and idles perfectly fine, the exhaust just smells off. not like unburnt...
White smoke on diesel engines, means water in combustion chamber. Blue smoke means oil.
In what condition was the filter you removed? How bad? Temperature issues? Missing coolant maybe? If yes, you might as well have an internal leak. Some gasket maybe. Check all you vital fluids levels. If anything missing, take the time to empty the engine oil on a can, and check the colour. If it will look like chocolate brown, then you do have a leak from the inside.
Sep 08, 2010 | Toyota Pickup Cars & Trucks
There is white smoke coming out of the exhaust pipes. Car will not accelerate normally. Car sounds like it is missing. Need spark plugs and oil change.
Unfortunately you have a blown head gasket. The white smoke you are seeing is anifreeze burning.
If it was blue smoke it would be burning oil.
Gasket is in the top of the engine and must be replaced or you will ruin the rest of the motor.
Usually it's a $1800 repair with parts & labour.
Jul 11, 2010 | 1998 Ford Explorer
Is there a drain location? How do I oil the fan ?if there is a noise could that be caused by the fan. Thanks
The drain is usually in the back of of the unit.
Fan motors are almost all 'oil-less.' I don't know of any 'new' Mfc putting motors (than can be oiled) on their units these days. You'd have to have a very old (15-20 year old) unit - that would have motors that could be oiled.
Fan motors will typically make noise when the bearings are going out - in which case the only cure is to replace the motor.
Note: it's possible you have a fan blade hitting against something - but it's not likely.
good luck!
Apr 25, 2010 | Maytag M6Y12F2A Air Conditioner
My new 2008 6x6 sportsman polaris fouls plugs every 3-6 miles
1) run a hotter sparkplug
2) if it is sitting for long periods of time your fuel could be stale
3) running the wrong fuel
4) worst case. engine is burning oil This can happen if service's was missed from new as oil becomes abrasive causing excessive wear.or motor was defective from new.
Sep 25, 2009 | Polaris ATV
I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman Garden
MISFIRE @ #4
How about a fuel injector? What engine?
May 04, 2009 | 1999 Pontiac Grand Prix
Fuel mixture for antiqur Maytag engine
30:1 would be better.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 03, 2009 | Washing Machines
Kitchen Appliances - Others Logo
147 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
