Question about Microwave Ovens
I need to replace the plastic button that is pushed to open door on the R1470a Sharp Microwave. where can I purchase this part?
  • Microwave Ovens Master
  • 9,125 Answers
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find handy exploded views at the Sears Parts Site.
You can find links to helpful exploded view diagrams and part ordering help
here. (Part prices for Sharp parts is usually best here)
I recommend that you bookmark that link to your favorites.
Posted on Dec 13, 2009
Lock faults
test this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aaubHCcG
Jul 30, 2013 | Sharp Microwave Ovens
When I push the door latch button on the sharp R-530BS the door will not open
you must replace the door latch parts.test the door hooks can be broken.
go to www.repairclinic.com and buy it. God bless you
Sep 23, 2012 | Sharp R-530BS Microwave Oven
The push button that opens the door on our Sharp Carousel R-1406F over the range microwave, is broken. We can push it in but it gets stuck. I cleaned it out because it was kind of dirty but it didn't...
It may be the door open button or the door button lever. Sometimes grease is the culprit, other times the surfaces where these two meet get worn, making the door harder to open.
You can find the full service manual free at our site here.
You can find Sharp part at the Sears Parts Direct Web site hereimage-4235112-10659157 or Encompass here.
You can find links to helpful exploded view diagrams and part ordering help for other brands here.
Jan 01, 2011 | Sharp R-1405 / R-140 Microwave Oven
Door opening internal plastic hinge broken
Just saw you post as I was searching for the same item. If you have not found the part yet, it can be ordered from repairclinic.com (part #916507). $5.50 plus shipping.
Apr 18, 2009 | Sharp R-1480 Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
Jul 28, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
