Question about Kenmore Ovens
31786034 Kenmore oven will not ignite. Any solutions?
I have the same problem with my kenmore 31786034 oven...what is wrong? it's only 15 years old! lol
Posted on Jan 13, 2010
Oven turns on gas but doesnt ignite until theres gas build up and has small explosion. kenmore model 362.75702001
What is causing that is a weak oven igniter that is not strong enough to fully open the gas valve yet just open it a little,letting gas accumalate in the oven then finally the igniter gets to full strenght and all the gas explodes. By replacing the igniter with a new strong one it will stop that.
The igniter is pretty easy to replace. Just remove the floor of the oven and the wing looking flame spreader, the screws that hold igniter to bake burner can be removed, and disconnect wiring.Then attach new igniter to burner reconnect wires and reinstall spreader and floor .
The part number for igniter is WB13K21 it could be purchased at your local appliance parts store or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
appliancepartspros.com
apdepot.com
I hope i have been able to help you fix your oven,
Gene
Aug 13, 2011 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Dec 02, 2007 | Ovens
Replace igniter part # 1990 in oven of model #3627332192
It's usually pretty simple. Start by turning power off to the oven - unplug it or disconnect power at the circuit breaker. Open oven door, remove all racks, then remove oven floor panel (it might be secured with two bolts or clips on the back side). Remove the flame spreader (one nut). Now you have the oven burner and igniter exposed. If the new plug differs from the old, cut off the plug and use ceramic wire nuts (should be supplied with igniter) to connect the wires. Don't shake the igniter - the coil is very fragile. Once the igniter is replaced make sure the wires are connected securely. Put everything back the way it was and test the oven.
Below are the two most popular oven igniters: flat bar igniter and round igniter.
Flat igniter - this is by far the most commonly used oven igniter. Includes all necessary pieces to replace longer ceramics. Size: 3-3/4" long. Fits Maytag, Whirlpool, KitchenAid, Magic Chef, Tappan, Jenn Air, GE (flat bar only), Sears Kenmore (flat bar only), even some Thermador cooktops and Viking ovens. - ff693fe.jpeg
Feb 25, 2010 | Kenmore Ovens
Kenmore oven doesn't light, replaced igniter and may have created a 2nd problem
If you follow the igniter wire harness, you will see a little relay in there that will probably need to be replaced.
May 30, 2009 | Kenmore Ovens
Kenmore Oven not working
Remove the bottom panel from inside the stove. Turn on the stove and see if the igniter glows bright red. If not glowing, replace the igniter. In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. In either case the igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 27, 2008 | Ovens
Kemore Gas oven - trouble igniting
Depending on the age of the oven, it is possible that your ignitor is now weak and it is taking longer to ignite.
Feb 03, 2008 | Ovens
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Broiler Works/Oven Doesn't
Jrzy, even though you can see the bake igniter glowing, that doesn't mean it's good. Igniters actually get weak (unlike a light bulb that simply burns out). It's hooked up in series to a safety valve (the valve that allows main gas into the oven) which actually reads the amps flowing through the igniter. If the igniter is weak and the amps are too low, the valve won't open up. Replace your igniter and you'll be cookin' with gas again. Tip---> before you unscrew your old igniter, put a little liquid dish soap on the threads for lubrication. This'll ensure it comes out with no problems.
Sep 14, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
209 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
