Question about Car Audio & Video
Pioneer HWM5469.
I NEED THE POWER SUPPLY USED IN A FORD RADIO. THIS PART NUMBER I AM TOLD IS FOR 3 CIRCUIT BOARDS. I ONLY NEED THE POWER SUPPLY BOARD. DO YOU HAVE THE PART AND PART NUMBER?
SOURCE: need circuit diagram for bush
Diagrams i am sure as you know are not always easy to come by, at least for free. I see that there are available boards online and a company that will rebuild this model of power board for you in UK. ohmsupplies.co.uk is where it is at. looks like $80
Posted on Oct 16, 2008
SOURCE: 04TA0691 power supply
Hi
I have a .pdf of the diagram - can you let me know your email so I can send it - it's too big to attach.
Glyn
Posted on Oct 31, 2008
Eagleeyes
  • 199 Answers
SOURCE: Ribbon cable between the face plate and mother board need part #
www.carradiospares.co.uk
mark
Posted on Nov 25, 2008
john224
  • 1378 Answers
SOURCE: circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Posted on Jun 13, 2009
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
My plasma PDP-503HDE exploded: a saw a flash flollowed by some smoke and it doesn't work any more
hi,
You have to check the power supply board. Its a common problem with the power supply of the Pioneer PDP. As it is using smd coponnents there is no repair possible with the power supply . You have to replace the power supply board with a new one. You can find the part number in the board. Serch with the part number to find a new board.
OK
Sep 24, 2011 | Pioneer PureVision PDP-503HDE 50 in....
Pioneer pro 940hd tv screen goes blank after 3-4
The is due to ether a bad backlight or bad inverter that powers the back light on this TV.
Ether would need repair you can get the parts @ www.partstore.com
Hope this information helps please do click the accept button for my efforts.!
Jan 02, 2010 | Pioneer Elite PRO-940HD Television
Wire color codes for '95 Ford stereo
i will post 96 Taurus. Not sure if the same as 95. you did not say which radio you have, base or premium.
please rate as fixya if this is what you need
Base Audio System With/Without Cassette Player
Pin Number Circuit Circuit Function 1 729 (R/W) Battery Feed 2 57 (BK) Power Ground 3 434 (LB/BK) Pulse Width Modulated Illumination Signal (Analog) from Headlamp Switch 4 1002 (BK/PK) IGN/RUN/ACC 5 640 (R/Y) IGN/RUN/START 6 694 (BK/LG) Logic Ground 7 — Not Used 8 — Not Used
Pin Number Circuit Circuit Function 1 593 (DB/W) Tape Audio RH + 2 594 (GY) Tape Audio RH - 3 57 (BK) Ground 4 833 (T) Audio Communications Protocol B 5 1068 (LG/BK) Audio system ON 6 723 (GY/R) Phone Wake Up 7 — Not Used 8 59 (DG/P) Rear Defrost 9 503 (BR/LG) Tape Audio LH + 10 504 (W/PK) Tape Audio LH - 11 — Not Used 12 832 (LB/PK) Audio Communications Protocol A 13 — Not Used 14 — Not Used 15 1010 (DB/O) Heated Back Window 16 — Not Used
Pin Number Circuit Circuit Function 1 803 (BK/PK) RH Rear Speaker (-) 2 802 (O/R) RH Rear Speaker (+) 3 811 (DG/O) RH Front Speaker (-) 4 805 (W/LG) RH Front Speaker (+) 5 801 (T/Y) LH Rear Speaker (-) 6 800 (GY/LB) LH Rear Speaker (+) 7 813 (LB/W) LH Front Speaker (-) 8 804 (O/LG) LH Front Speaker (+) 9 — Not Used 10 747 (R/PK) Power Antenna (Up Signal) 11 — Not Used 12 694 (BK/LG) Ground 13 694 (BK/LG) Ground 14 720 (R/Y) B+ Supply
Mar 06, 2009 | 1995 Ford Taurus
Remote wire?????
The old pioneer car radios solved this problem by supplying the battery power to the radio from the amp. When the radio turned on, it began to draw more power from the amp supply lead and this would turn the amp on. It was a simple circuit in the amp that only used one or two transistors. You may need to build this circuit or find a manufacturer of a similiar circuit. In the short run, you can use a small toggle switch to supply the trigger voltage (+12 volts) to the trigger wire connection on the amp. Good luck.
Nov 18, 2008 | Audio Players & Recorders
TV repair person told me my Toshiba 50HP16 Main Power Supply Circuit Board is bad as well as a secondart board. How do I identify these boards and get part numbers? Its too expensive to have the repair...
Even if you buy the parts you may get sticker shock!!! Why did it need a power supply and another board. Will your set come on? I may be able to give you part numbers but you need to be specific about which other board you think you need such as X Y signal board or power supply Some single circuit boards for some sets are as high as 600 bucks hope not for you
Sep 19, 2008 | Televison & Video
Continuing questions from Tony Fidaleo
I've sent you an email to request the copy of your PDF file to see what part in the circuit is making the fuse blow.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Tony Fidaleo's Pioneer PRO-700HD
Once I look at the schematic diagram, I might be able to know the part that is blowing that fuse.
I need to know if i can fix mt tv a repairman told me that the power supply needs to be fixed
Whats the model number? Let me know that as it may be as easy as replacing the power supply circuit board depending on the model number of your set.
May 21, 2008 | Televison & Video
Supply board
The power supply board for this model can be found in the link below.
Buy PDP-5030HD Power Supply Board
Mar 20, 2008 | Pioneer PureVision PDP-5030HD 50 in....
PDP-502MXE dead set
hi all,
this problem lis the power supply board. be aware that pioneer pdp-502mxe has got 3 versions and all 3 power supply boards are different so before ordering a new or reconditioned one check the part number on the power board itself.
pioneer is not replacing the boards anymore.
check on ebay.co.uk
i did sold so many parts from this model.
thanks
Jan 08, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Car Audio & Video Logo
314 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
