Question about Cell Phones
How do you turn off the tone when pressing the key board? How do you set a short cut for the phone book?
NET10 W408g does not allow using the Xlink gateway fully, especially sending DTMF codes to automated systems.
Jim
Been a long time since I have seen this phone but I seem to remember a setting like this. Some phones had a long and short setting too.
Mark
Motorola Support
Activate DTMF tones: Menu > Settings > Initial Setup > DTMF When you dial a number, your phone sends it to your network as Dual Tone Multi Frequency (DTMF) tones. To send DTMF tones during a call, just press number keys or scroll to a number in the phonebook or recent calls lists and press Options > Send Tones
Dec 17, 2012 | Motorola Mobility W408g - Silver net10...
I want to make my phone touch tone
I presume you want to use tone dialling..If that is the case the solution should be same as my phone.. Press Menu then scroll using up/down arrow key to "Initial setting" and press(soft key) Select, then scroll to "set tel line" press(soft key) select, then scroll to "Set Dial mode" press(soft key) Select, then scroll to "Tone" , then press(soft key) Save then press Off button.**This is done via handset**Soft keys are the ones under screen*** I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-TG2313 Cordless Phone
I just want to stop the keys making a noise when I text
Hi there!
If you're hearing a noise or a tone whenever you text then ill be advising you to check the tone settings on your phone.It might be that the KEYPAD TONE in your phone is enabled.
If you want to adjust the volume of youe keypad tone then you can just go to SETTINGS.And after that please go to TONES/TONE SETTINGS and kindly look for KEYPAD TONE.You can lower down or turn off the volume of the keypad tone on that option. If you have another kind of phone then you can try looking for small buttons on the side of the phone. You can press the "Down" button to lower the key volume. Please press it repeatedly to continue lowering the volume. Press "Up" button if you decide to turn the key tones back on.
THANKS graham569!
Apr 20, 2011 | Cell Phones
I just got a verizon b.b. 8703e and I can't figure out how to turn on the ring tone
A ring tone can be set for specific contacts on a BlackBerry smartphone that has 32MB or more of flash memory.
To set a ring tone, follow the steps below:
1) Click the Address Book icon on the Home screen
2) Select the contact that a custom ring tone is being added for.
3) Press the Menu key and click Edit.
4) Press the Menu key again and click Add Custom Phone Tune.
5) Select the ring tone from the list of available ring tones.
6) Press the Menu key and click Save.
Nov 02, 2009 | RIM BlackBerry Storm 9530 Smartphone
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
Samsung J700i mobile phone instruction book
go to phone pofiles in normal profile select edit then select key pad tone and pop-up alert tone turn both off
Aug 08, 2009 | Samsung Cell Phones
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Sounds when numbers are touched.
Sound Settings:
Idle screen
Menu Soft Key
Select Settings soft key
Press Down Key
Select profiles
(change whatever profile you want to use)
Options, Edit (left soft key)
Press Over to you get to the Phone Icon...
Keypad Tone
Press Center Key (att key, or cingular key in ther middle)
Press Beep, Clean, or Mute....
Page 79 on manual
Jan 08, 2008 | Samsung SYNC SGH-A707 Cellular Phone
GE28112 Dect phone
Here are the instructions and a link to the manual :
Key Tone
From the Handset Setup Menu:
1. Press the caller ID-volume ( 6 or 5) button to scroll to the KEY TONE sub-menu.
2. Press mute/program button to enter the menu. SET KEY TONE 41ON 2 OFF shows in the display. The default setting is 1ON.
3. Use the touch tone pad on the handset to select 1 or 2, or use the caller ID-volume ( 6 or 5) button to scroll to your selection.
Here is a link to the manual for you :
http://telecom.hellodirect.com/eBiz/pdf/phones/GE_28111_Manual.pdf
Jan 05, 2008 | GE 28111 Cordless Phone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
