Question about Acer Aspire 5610-4648 Notebook
Vertical white line goning from top and bottom. Help
I have a 5610 acer. The vertical line went away for awhile and now its here to stay. Help
  • 143 Answers
The screen will probably have to be replaced. Try gently squeezing around the edge of the lcd where the line is present. Sometimes this will get it going temporarily. I have even used close pins before to keep pressure on it to keep it on. A new screen can be ordered on ebay for around $100 and are fairly easy to replace. I recommend getting the exact part number on the back of the LCD before ordering.
Posted on Dec 12, 2009
Testimonial: "Thanks You have been very helpful 5 thumbs up"
I HAVE A HALF SCREEN. BOTTOM HALF LOOKS GOOD TOP HALF HAS WHITE LINES WITH A BIGGER WHITE LINE SEPARATING THE TWO. IS THE PICTURE TUBE GONE OR IS THERE AN ADJUSTMENT I CAN MAKE? TV IS A RCA F25645
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Jun 15, 2011 | RCA F25645 25" TV
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
TV TURNS ON WITH NO PICTURE BUT YOU CAN HERE
you need some caps changed in that set in vertical circuit
i usually change about 5 caps to cure the problem
caps go bad over time
Dec 27, 2008 | Panasonic CT-32G11 32" TV
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Display problem
this is a lcd panel problem not repairng this panel
its is coberage of warranty change lcd panel
    god luck
Oct 23, 2007 | Acer Aspire 3680 Laptop
Thin Bright line is all I got on the tube
Sounds like a capacitor and/or the Vertical amp Ic has gone out in the set. Maybe a bad solder joint. Depending on where you live, the cost of repair could be between $100.00 to $150.00. Kill it or what? What would Braveheart do. FFFRRRREEEEEEEDDDOOOMMMM
Mar 18, 2007 | JVC AV-27850 27" TV
Acer Aspire 5610-4648 Notebook Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
