Question about Garden
How do you do the timing on a victa lawnkeeper? I know it is 3 deg but there is no marks so how do I tell where the 3 deg is?
The curent victa 2-stroke engine(power torque) does not have adjustable timing. All you do is set the air gap between the coil & flywheel and its set. The simplicity of modern electronics has done with points etc
The previous Victa 2 stroke engines sometimes had points which is located under the flywheel - on these you need to first set the points gap. Now the actual timing is 1/8 inch BTDC. The coil & points are on an adjustable frame ( plate or whatever you call it) which is secured by 2 bolts ( 7/16" headsize size from memory) - loosen these 2 bolts and you should be able to rotate the assembly about 1/2 ".as it has elongated boltholes. Rotate the motor (clockwise looking down) so the piston is 1/8" BTDC if its correctly timed the points should just be opening. Move the coil/points assembly ( & tigten the 2 bolts each time) till you get it right, In practice the timing does not need to checked - if it ran OK before then if you need to disassemble ,mark the coil/points plate & engine body so you dont change the timing
Posted on Dec 29, 2009
I own an old Victa LawnKeeper that has a Tecumseh four stroke motor. What spark plug suits it? There is nothing on the motor itself and the plug is gone! Does anyone know?
most any mower spark plug will fit
all you have to be aware of is the thread length
you can measure it with a bit of bent wire from inside the head to the plug seat and any plug with that length will fit
Feb 05, 2017 | Tecumseh Garden
How do i set the timing of victa altima lawnmower,i just want to know where the mark of crank shaft and cam shaft must point? it is a one piston engine with two valves
There is a mark on crank gear, and there is a mark on cam gear. These two marks may be a circle, a dot, a triangle or possibly something else. The idea is two marks must be placed together for gear timing to be correct. I hope this is what you are asking. Please let me know how you make out. GOOD LUCK FRIEND.
Jan 10, 2015 | Garden
I own a victa 35 classic lawnkeeper. I tried to start it for few days now but it is hard start. As I don't know much on small engine, can you tell me if I had to refill engine oil or replace engine oil...
Yes you need to change oil on lawnmowers at least once a year. I would check three things. Compression, spark and fuel to carb. You can purchase a compression tester and spark tester at any local auto parts store. Check these first, if compression and spark are good you know your problem is carburetor/fuel related. I hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 10, 2013 | Garden
Which line on the harmonic balancer do i use to line up with the timing plate?
The manufacturers ignition timing specification for a 1992 Chevrolet S-10 Blazer 4.3L V-6 (VIN CODES W and Z) is 0 Deg. at idle with the EST bypass connector unplugged. You do not have to worry about which line to use on the balancer. There will only be one of them that is even close to the pointer on the timing cover. When the line on the balancer is aligned with the mark on the timing cover with the timing light, you are done.
If you really think you REALLY need to know which line is which, then pull #1 spark plug out and using a screwdriver or a punch in the spark plug hole, rotate the engine slowly to find where top dead center is. When you find top dead center on the intake stroke, the line on the balancer that is aligned with the mark on the timing cover will be the one you want to use (the other line will not even be close on the intake stroke OR the power stroke.)
Now, if you have your engine modified or something, (I don't know why you are asking someone at a performance shop or why he is telling you 8 to12 Deg. BTDC) then what you need is a timing light equipped with an offset adjustment. You set the offset on the light where you want it (i,e. 10 Deg.), then you align the timing marks as you would for a "normal" engine. You do not need any other marks on the timing cover. (Which is why the manufacturer did not bother to supply them for you.)
Feb 29, 2012 | 1992 Chevrolet S-10 Blazer
I know how to kinda do the timing but when i have the timing light on the marks i dont know which mark is suppose to be the 4 deg tdc.
Your auto's spec sheet should tell you what your timing degree should be. For example, a 1969 Ford 429, 6 Degrees BTDC @ 550 rpm in drive gear - with automatic trans, with a firing order of 1-5-4-2-6-3-7-8. All this means is that you want to line up the pointer on the timing light with the 6° timing mark when the engine is idling in gear at 550 rpm. As you can see, it also says something about "BTDC" for this Ford. There is also an "ATDC." "Before Top Dead Center" and "After Top Dead Center" - top dead center is the point where the piston reaches the highest point in the cylinder and that is when the compression is the greatest. Now, your timing marks with have a line labeled "0" with marks above and below it, and depending on which way the wheel rotates, you will see the lines before the "0" (BTDC), or after the "0" (ATDC)
Aug 05, 2010 | Chevrolet Impala Cars & Trucks
Change engine oil
Check underneath the mower at the bottom of the engine's crankcase and see if there is a possible plug of any type there. Be sure you lift the mower the correct way when tipping , typically with the control handles going down towards ground...not on its side.
Jun 08, 2010 | Briggs & Stratton Garden
Do you know the firing order on a 1981 fiat x19 1.5 engine
X1/9 1500,
Ignition system type: CB
Ignition coil make/type: Lu/DLB101
Supply voltage: n / a
Primary resistance: 2.4-3.3 Ohms
Secondary resistance: 3330-4070 Ohms
Distributor make/type: Ma/S135LX
Contact breaker gap/air: 0.4 mm
Dwell angle: 52-58 Deg
Ignition Timing - unleaded: n / a Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 5/800 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: N/S/R
Firing Order: 1-3-4-2
Spark plug make: Bosch
Spark plug type: WR6DC
Electrode gap: 0.7 mm
Mar 25, 2010 | Fiat X1/9 Cars & Trucks
Garden Logo
1,256 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
