I have an old hotpoint dryer and it will not run. I can hold the switch to start it but it sounds like it wants to run but doesn't run.
  • 6,784 Answers
HI. The start switch may be the culprit here. I would test the operational value of the start switch, and door switch. Follow the procedures below to isolate the issue.
START SWITCH
Locate the start switch(Usually located in the control panel housing). it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
For a three wire switch, touch one probe to the terminal labeled NC (or CT1) and touch the other probe to the terminal labeled CO (or R1). You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
If the switch fails either test, it should be replaced.
DOOR SWITCH
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
Posted on Dec 12, 2009
  • Michael Masters
    Michael Masters Dec 12, 2009
    NOTE_ If the start, and door switch test out ok, this will lead to a weak motor(windings failure). Replace the motor if the start switch and door switch are operational.
Why would the dryer only run when holding the start switch
more than likely a bad push start button switch, test it with a meter
Aug 07, 2014 | Hotpoint Dryers
Will not start unless holding the start switch for minutes, sounds like a car that will not start
Sounds as if the motor is going bad. Soon it will simply buzz and won't start at all. It's the motor windings and the only solution is to change out the motor.
May 18, 2014 | Hotpoint Dryers
Hotpoint dryer runs as long as i hold the switch, but it turns off as soon as i let it go
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 29, 2011 | Hotpoint NLL113EYWO Electric Dryer
How do i change the language on my hotpoint wmd960p washing machine. The language is currently set to french and i want it in english
Hotpoint kindly omit this from the manual. Love 'em!
I believe that You hold the i (info) button and delayed start button simultaneously for five seconds, then the screen reverts to the language choice page. The machine needs to be switched on.
Drop me a note back if this doesn't work
Aug 25, 2011 | Hotpoint Ultima WD72 Front Load...
Out hotpoint dryer is 8 years old and juist
Sounds like the drum bearing or shaft is worn.
Remove rear panel of dryer, you should see the drum shaft, check for wear here.
Jan 17, 2010 | Hotpoint Dryers
Hotpoint nbxr463eb2ww dryer will not start
turn breaker off and push off hard till you can feel an hear the click to reset then back on
Aug 31, 2009 | Hotpoint NBXR463EBWW Electric Dryer
The dryer will not stay running.
When you hold the start switch you are energizing the start winding of the motor. If the motor does not take off and run, the most likely cause is the centrifugal switch inside the dryer's motor is not being switched. It is switched by a spring loaded collar on the motor shaft which moves when the motor starts to run, and again back when it stops. Often times this collar begins to stick on older dryers. Sometimes you can free it up by cleaning the dryer motor with an air compressor and hitting the collar with some spray lube. This only works some times. The only sure fix is to replace the motor, which unfortunately is rather expensive and a fair amount of work. Please don't bother rating this, as anything but a Fix-Ya lowers my score.
Jan 11, 2009 | Hotpoint NLL113EYWO Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Just buzzes
 the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Jul 25, 2008 | Hotpoint NVL333EY Electric Dryer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
